PTO shaft for Howard Rototiller
   / PTO shaft for Howard Rototiller #1
crewcab_dumptrk
Hello,
I just purchased a Howard HN Rototiller for my YM1610D and need the front PTO yoke. It came with the rear section of the PTO shaft including the slip clutch, but is missing the front section that attaches to the PTO output shaft and slides into the PTO shaft square opening .
Any information regarding how to find/purchase or make a replacement would be greatly appreciated.
   / PTO shaft for Howard Rototiller #2
tractor supply has a large assortment of shafts and parts.
About two months ago I bought the tractor end of a square drive shaft for a rotary cutter.
check prices close you may can buy a new pto shaft with sheilds and couple to your slip clutch for a little more $.
check northern tool's web site and other ag supply places on line.
hope this helps. love my 48" king cutter tiller.
   / PTO shaft for Howard Rototiller #3
Best place would be a dirve line shop if you have one local. If not the seal company, C/R has a full line of drive line parts that you can get from any bearing company that carries C/R seals. Messed up the cover for my Howard and found a new one in stock at our local drive line shop. Found the couple of parts I needed for my Howard HR8 easy to get at a local tractor dealer.
Chris
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2018 Genie GTH-636 (A50123)
2018 Genie GTH-636...
2013 Great Dane 53ft T/A Reefer Trailer (A51692)
2013 Great Dane...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
