PTO Shaft-Education needed!
   / PTO Shaft-Education needed! #1
Scotty370
Platinum Member
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
In my build, I've reached a dilemma. I don't know, nor can I find good PTO driveshaft info. About as far as I've gotten is that the measurements appear to be between the yoke pins when retracted. The working range is sketchy at best! It appears that 10" is the norm, but longer shafts obviously must give you more than that. Also, nowhere can I find acceptable deflection angles at the yokes. Also can't find dimensions on, yoke pin to end of collar, or good measurements on slip-clutches. Thought I'd break this out of my original thread to reach a larger audiance! Thanks in advance! ~Scotty
DHE 38-7 7 SHANK ALL PURPOSE PLOW (A51243)
DHE 38-7 7 SHANK...
2014 Mack CXU 613 Semi (A50514)
2014 Mack CXU 613...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2015 Ford F450 Service Body (A47384)
2015 Ford F450...
