PTO Shaft Cover safety chain attachment options?
   / PTO Shaft Cover safety chain attachment options? #1
JCoastie
Platinum Member
Coastal AL
LS MT240HE
Had a failure that busted the little plastic mounts that the PTO cover safety chains mount to.
Anyone have unique options that they have used to secure the safety chains back to the cover?
Pictures would be great if available.
   / PTO Shaft Cover safety chain attachment options? #2
I had that problem with a tiller. My dealer ordered a new "bell" and I put it on.
A tip, don't hang the pto shaft by the safety chain while in storage. If it gets bumped a little to hard the little plastic mounts break off and then you need to buy a new bell. BTDT ;)
   / PTO Shaft Cover safety chain attachment options? #4
I managed to rip a chain through the plastic ring. I just pushed it back through the slot and it's been staying there fine. If you must have a new attachment point you may be able to drill a hole through the bell and secure the chain with a bolt and washer or a carabiner.
ZIP tie on shaft cover behind bell(?)...
Thanks for that! I was thinking hose clamp, but I wanted something that was breakable/sacrificial, didn't think about a zip-tie. Done deal, thanks!
2015 Acura MDX (A50324)
2015 Acura MDX...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2012 DOOSAN G90 GENERATOR (A50854)
2012 DOOSAN G90...
2008 FORD F-750 (A50854)
2008 FORD F-750...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2008 FORD F-350 (A50854)
2008 FORD F-350...
