PTO shaft broken
   / PTO shaft broken #1
roller
Bronze Member
Suffolk England
kIOTI CK30
I have a ck30 with broken/snapped shaft [internal],been told it was a manufacturing fault, and kioti have taken full resonsability no quibles their!!
Now this shaft broke 2 weeks today and i'm still waiting for it to be repaired ,apparently their STILL waiting for a few parts to come in from KOREA..
Anyone else heard of shafts snapping??
   / PTO shaft broken #2
Nope.
   / PTO shaft broken #3
Nope, and I have certainly killed the engine while brush mowing until I got the slip clutch properly adjusted.
   / PTO shaft broken #4
Never used mine. Hope it doesn't go the first time I do.
This is the first time I have heard of this problem being mentioned in this forum, so it looks like a unfortunate fluke to be the first! :mad: Good luck on your repairs.;)
   / PTO shaft broken #5
What were you running when it snapped, if you don't mine me asking? I'm Curious?
Steve
   / PTO shaft broken
Steve
Flail mower.
   / PTO shaft broken #7
Never heard of that either, Were you using slip clutch or shear bolt for protection?
   / PTO shaft broken #8
Broke PTO while using a flail mower? I'd say the belt(s) are too tight on your mower. I use a flail mower alot and have stalled it to the point of burning up the belts. The drive belt(s) are there to protect the mower gear box and the PTO/tractor. I've heard of broken PTO's but that was caused by sudden sock load i.e. 'tiller with no slip clutch or engaging the PTO at too high of engine RPM. So I would tend to believe that it was just a "fluke".
   / PTO shaft broken #9
are you sure the shaft broke? I have seen the internal over run clutch not working properly..... so the shaft doesn't drive.
2011 Chevrolet Traverse 1LT SUV (A50324)
2011 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Massey Fergusson 4253 (A50120)
Massey Fergusson...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
43014 (A51691)
43014 (A51691)
