PTO selector lever wont engage
   / PTO selector lever wont engage #1
CTMassey
Massey-Ferguson 1529
Hi all, on my MF1529, got done blowing some leaves with the PTO driven blower( about 1.5 hrs) , shut off the control switch then moved the selector lever back to neutral.....10 minutes later decided to blow some leaves next door and cant get the selector lever to move from neutral to 540 to engage the gear drive...I haven't "forced " it yet but ive never had this trouble before...any comments/suggestions?? thanks in advance
   / PTO selector lever wont engage #2
I have a '81 JD with power reverser transmission that is hard to engage/disengage sometimes with its manual PTO lever, especially when using something with a high rotational mass like a wood chipper. Usually, it only takes a quick RPM change, then disengaging the foot clutch while trying to move the lever to let it slide into the engaged or disengaged position. So, try bumping the RPM a little to see if that works. [ worth a try ] Good luck, Jerry... :)
Club Car Utility Cart (A55853)
Club Car Utility...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
Dayton 32965 80-Gallon Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
