PTO selector lever wont engage
   / PTO selector lever wont engage #1
CTMassey
Bronze Member
Massey-Ferguson 1529
Hi all, on my MF1529, got done blowing some leaves with the PTO driven blower( about 1.5 hrs) , shut off the control switch then moved the selector lever back to neutral.....10 minutes later decided to blow some leaves next door and cant get the selector lever to move from neutral to 540 to engage the gear drive...I haven't "forced " it yet but ive never had this trouble before...any comments/suggestions?? thanks in advance
   / PTO selector lever wont engage #2
I have a '81 JD with power reverser transmission that is hard to engage/disengage sometimes with its manual PTO lever, especially when using something with a high rotational mass like a wood chipper. Usually, it only takes a quick RPM change, then disengaging the foot clutch while trying to move the lever to let it slide into the engaged or disengaged position. So, try bumping the RPM a little to see if that works. [ worth a try ] Good luck, Jerry... :)
Brush Bandit 200UC (A52377)
Brush Bandit 200UC...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
2020 Hino 195 16ft Electric Box Truck (A51692)
2020 Hino 195 16ft...
1987 Ford F-250 Wrecker Tow Truck (A51692)
1987 Ford F-250...
