PTO Ratios
   / PTO Ratios #1
Eagle Dude
Fountain Inn, SC
Yanmar 2210
Does anyone know the Ratio of Engine RPM to PTO RPM on the Japan version of the Yanmar. Specificly YM2210. I know 1st gear is the closest for 560 RPM equipment and I think 1st PTO gear is 2:1, or if the engine is at 1000 rpm then the PTO is 500 rpm.
   / PTO Ratios #2
Somebody who owns a 2210 will give you a more precise answer, but I think its tachometer has a tic mark at 2200rpm, which gives 540rpm at the PTO.
So roughly 1:4 in PTO first gear.
Does your tachometer look like this one?
   / PTO Ratios #3
I think the pto speeds are
1st= 547
2nd=700
3rd=929
4th=1232
and that is at an engine speed of around 2200rpm.
Hope that helps,
Aaron
Hoye Tractor Parts
(940)592-0181
Contact Us
   / PTO Ratios #4
What PTO speed is a Yanmar RS1303 tiller designed for?
   / PTO Ratios #5
My understanding is that it can be used in any/all of them. It just depends on your current soil conditions and the final soil texture you are looking for.
Aaron
Hoye Tractor Parts
(940)592-0181
Contact Us
   / PTO Ratios
Looks simular but is only marked in units of 500, no extra ticks
1st= 547
2nd=700
3rd=929
4th=1232
Hope that helps,
Aaron
Hoye Tractor Parts
(940)592-0181
Contact Us
Thanks for the info both of you were really helpful.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2014 Doosan DA30 (A52748)
2014 Doosan DA30...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
