PTO Question
/ PTO Question #1
SevenCorners
Charlottesville VA
Jinma 224 2004
Just a silly question. Does the 224 PTO spin in both forward and reverse directions? I have not noticed and I am getting ready to use my PHD for the first time to dig 120 holes. I am hoping to use the reverse if it gets dogged down in the hole.
Thanks
/ PTO Question #2
Multi-speed, but uni-directional. If it gets stuck in a hole, simply disengage the PTO (if the shear pin hasn't already broken) and use the TPH to lift it out.
//greg//
/ PTO Question #3
One direction and that is DIG. Lower your 3PH SLOWLY so you don't get too much bite. Safety is a real concern. Don't let anyone near the auger when the PTO is engaged. If you ever used a manual pair of hole diggers then you will love this implement. I don't use it often but it is one of my favorites.
/ PTO Question
Thanks guys I hate to ask a stupid question. Appreciate no one pointing it out.
/ PTO Question #5
I got mine stuck a few times. A handy tool to get it unstuck is a 24" pipe wrench to back it out a quarter turn if it gets wedged under an object. It got stuck a few times on me and using the 3 point hitch only squeezed down the rear tires..Make sure the tractor is shut down when backing out the auger...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
CAT 966G Grapple (A68134)
CAT 966G Grapple...
2013 BOMAG BW211D SMOOTH DRUM ROLLER (A67714)
2013 BOMAG BW211D...
2017 Ford F-250 Ext. Cab Knapheide Service Truck (A66736)
2017 Ford F-250...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
