PTO question
   / PTO question #1
bunyip
Elite Member
Flynn Victoria Australia
Kioti DK 5810 HST
I keep my BX in a locked shed and as an extra security precaution have the park brake engaged, hi-Lo in neutral, FEL locked and PTO engaged, with these in place it will slow down a potential theft but I am wondering if the PTO being engaged is likely to do any damage to the beast, it won't start while engaged but I wonder about fluid moving to where it shouldn't.
   / PTO question #2
Engaging the PTO is the same type of thing internally as shifting gears. No damage. The clutch having to be depressed would also prevent any extra load or strain when trying to start the “beast” BX.
   / PTO question #3
It won't hurt anything.
   / PTO question #4
It's just an electrical lockout that prevents starting. Disturbingly effective at times even if you were the one that did it intentionally. The gears will be in mesh instead of out of mesh, but a most of the gears in the transmission are in that state running or not. There wouldnt be any tranny issues at all if you could start it with the PTO engaged. You might kill the starter with the extra load or cause safety problems with the impliment starting to spin. But not with the tranny.
   / PTO question
Thanks, I thought that would be the case but didn't want to incur a bill I could live without, must admit that I have unintentionally done it before and tried to start it, the more delays I can put in place the better the odds.
2015 KENWORTH T680 (INOPERABLE) (A52472)
2015 KENWORTH T680...
6 STEEL KENWORTH T800 BUMPERS (A52472)
6 STEEL KENWORTH...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
