PTO Question
   / PTO Question #1
katoomed00
Youngsville, La
TYM T503, Kubota BX24
OK, I hesitated posting this question because it makes me feel like a dummy, but I just can't figure out the correct engine RPM to get the 540 PTO speed on my T503HST.
It's new and I haven't used the PTO yet.
Also does anyone know if the PTO shaft reversible to achieve a 1000 RPM set-up?
   / PTO Question #2
Your pto will be given 540 rpm at a specific given engine rpm. Most manufactures now label this right on the tach. Check with your owners manual or with your dealer.
As far as I am aware 540 pto is a 540 pto. Some tractors have a 540 and a 1000 rpm pto to give you both options.
Year make and model of the machine ??
   / PTO Question
Thanks Diesel Lover, I did go back look again at the manual, I found what you mentioned under the Cab layout area when I looked at the Tach.
I assumed it was like my BX24 where as the digital tach. needed to indicate 3140 or so to achieve the 540.
2013 TYM T503HST Cab.
Thanks for the insight
Darrell
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2021 Gator Made Trailer, VIN # 4Z1GF3029MS010209 (A51572)
2021 Gator Made...
Laymor SM450-ST Sweeper (A51573)
Laymor SM450-ST...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
