PTO push button won't engage (4110)
   / PTO push button won't engage (4110) #1
patchfarm
Parsonsfield, Maine
None
The push button for the PTO on our 4110 won't engage. You push it, the red lens lights up, but it doesn't hold/click as it should, it just slides back out. I have tried with the toggle PTO switch in all 3 positions and that doesn't affect it at all. Any thoughts? I can't get a new one until later this week at the earliest, and we're on the verge of getting around a foot of snow so I need the PTO for our snowblower. Anything else I can check? Or is there any way to bypass that switch and trigger it manually somehow (dumb question?)?
   / PTO push button won't engage (4110) #2
Will the PTO operate if you keep the button pressed in?
   / PTO push button won't engage (4110) #3
I don’t know anything about Mahindra tractors, but if the pto button on my MF doesn’t “hold” when I engage it, I’ll increase the throttle a bit (I try to engage the pto at a low throttle position so that it doesn’t slam into action)
   / PTO push button won't engage (4110) #4
This happened to mine a couple times these past few years and I just carefully disassembled the switch and cleaned it up some and reassembled with just a little dielectric silicone grease and it works again for a year or two.
   / PTO push button won't engage (4110) #5
I'll repeat MWaynes question, will the PTO engage with the switch manually held in? If not there is a wire near the hydraulic filter (under the RH side step) you need to check. I have a 3510 and caught it once on some underbrush which shut off the PTO. Its one single wire with a bullet connector.
   / PTO push button won't engage (4110) #6
A bit of a silly question but have you checked that the selector lever under your left foot is engaged? It does happen
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
1270 (A50490)
1270 (A50490)
John Deere 920 Platform (A50514)
John Deere 920...
2004 GREAT DANE 53FT DRY VAN TRAILER (A52141)
2004 GREAT DANE...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
