PTO push button won't engage (4110)
   / PTO push button won't engage (4110) #1
patchfarm
Parsonsfield, Maine
None
The push button for the PTO on our 4110 won't engage. You push it, the red lens lights up, but it doesn't hold/click as it should, it just slides back out. I have tried with the toggle PTO switch in all 3 positions and that doesn't affect it at all. Any thoughts? I can't get a new one until later this week at the earliest, and we're on the verge of getting around a foot of snow so I need the PTO for our snowblower. Anything else I can check? Or is there any way to bypass that switch and trigger it manually somehow (dumb question?)?
   / PTO push button won't engage (4110) #2
Will the PTO operate if you keep the button pressed in?
   / PTO push button won't engage (4110) #3
I don’t know anything about Mahindra tractors, but if the pto button on my MF doesn’t “hold” when I engage it, I’ll increase the throttle a bit (I try to engage the pto at a low throttle position so that it doesn’t slam into action)
   / PTO push button won't engage (4110) #4
This happened to mine a couple times these past few years and I just carefully disassembled the switch and cleaned it up some and reassembled with just a little dielectric silicone grease and it works again for a year or two.
   / PTO push button won't engage (4110) #5
I'll repeat MWaynes question, will the PTO engage with the switch manually held in? If not there is a wire near the hydraulic filter (under the RH side step) you need to check. I have a 3510 and caught it once on some underbrush which shut off the PTO. Its one single wire with a bullet connector.
   / PTO push button won't engage (4110) #6
A bit of a silly question but have you checked that the selector lever under your left foot is engaged? It does happen
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
John Deere 652R (A50121)
John Deere 652R...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
2018 Caterpillar...
