design
Has any on considered attempting the following?
During a transmission fluid change, drill and tap the transmission drain plug for a 1/2" npt tread. Add a 1/2" nipple (coming straight down), an elbow and a short piece of 1/2" pipe (heading straight back to the rear of the tractor) to a quick disconnect secured to the rear differential housing.
Modify the fill cap to allow for a return flow path.
Then one could add a PTO pump with an integral filter on the intake line to the new rear hydraulic feed line. Add the appropriate pressure relief valve and quick disconnect to the high pressure side of the pump.
Combine the flow that bleeds off from the pressure relief valve to the return lines from the implements and dump into the modified fill port, (AKA the plastic fill cap)
If one does this, you end up with the transmission being the fluid reservoir for the PTO pump. This would allow you to have access to 10 gallons of hydraulic fluid on board at all times.
1. Will the flow rate for a PTO pump by so high that there are air bubbles entrapped in the fluid in the transmission?
2. Will this hurt the other hydraulic pumps on the tractor?
3. Other issues?
-Design
3. Other issues?
-Design
