PTO pump quick connect
/ PTO pump quick connect #1
RiZak
East Angus , Quebec, Canada
kubota L1802DT
Hello all!
Last year I grew tired of the flow given by the hydraulic pump on the tractor so I installed a PTO pump to run the back hoe. I could not figure out a place to install a tank on the tractor itself so I installed a tank on the bh. Not wanting to starve the pump and in a little hurry to enjoy 9 GPM instead of 4.5 I just connected the tank straight to the pump with a 1" suction hose.
Now, twice this year alone I removed the BH. So I also had to remove the pump. This is a pain since there is no room between the BH and the tractor to pull off the pump. I have to move the tractor a couple inches many times after the BH is off. Also, no room to install longer hoses...
I have a quick connection on the pressure side and I wonder if there would be something availlable for the suction side. This would allow the pump to be used with other implements I have or planning to get sooner or later.
in the mean time, if somebody have a good idea on where I could install a 15 gallon tank on a kubota L1802DT (I did'nt know it was a gray market when I purchased) I would be more than happy.
Zak
/ PTO pump quick connect #2
Yes there is - pricey, but available:
Hydraulic Quick Disconnects
I suspect the problem will be the restriction that any of these impose in the line.
IOW, a fitting for a 1" (I.D.) hose may have something less than a 1" hole inside, therefore a restriction .... not exactly what one wants on a suction line.
/ PTO pump quick connect #3
behind the seat maybee.ie inbetween the rops, above the toplink area..
soundguy
/ PTO pump quick connect #4
I'd just use a hose-nipple & a camlock of whatever size you want.
A ball-valve just before the camlock on the hose end for pump would minimize oil loss when disconnecting.
A standard camlock should be fine....since no pressure on suction line. You already have hose rated as a suction hose I imagine?
/ PTO pump quick connect #5
The tank on mine is under the backhoe and the hoses are long enough I back up close and hook the pump and engage the pto, then back up real close and use the hoe to line up to connect to 3pt.
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2715SSFL (A61567)
2715SSFL (A61567)
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
