PTO Pump driven with Jackshaft
   / PTO Pump driven with Jackshaft #1
N8ghz
Eastern Ohio
(2) IH284Diesels,GE-E8m,GE-E14 Elec-Trac's
Hello. I am trying to drive a Prince PTO pump (540rpm-21gpm), via a jackshaft off of a 65hp Wisconsin V465D Engine. I acquired this pump mainly for it's GPM for speed on a log-splitter/mini firewood processor I am building.
I so far have built a pulley drive using (4) 3v belts from the crankshaft to a 10.6" jackshaft sheave. The ratio is 3.03:1 which should be about 528 PTO @ 1600 engine or 594 PTO @ 1800 engine.
The problem is getting pressure. Belts squeel badly and it don't look like I will be able to get over 1100 psi no matter how tight I draw the belts. I do have a gauge on a test valve to the splitter cyl (4").
I am now going to change the jackshaft to chain....RC80.....13 into 38 teeth.
According to Prince specs, even 1500 psi will require 23.8 hp, while getting to 2000 psi needs 32.1.
I may make the 23.8 with the RC80 chain if I stay under 1100 RPM, but HP drops off rapidly above that with a 13 tooth driver.
I have (10) 3v steps on the crank pulley now, but even using all of them for belts seems futile.
Any ideas?....
Maybe I should forget using this pump? or maybe move to a 5" cylinder and
live with the lower PSI....the remaining hydraulic functions do not need this GPM or PSI.
   / PTO Pump driven with Jackshaft #2
SPECIFICATIONS
9.9 Cu. In. displ.
2,250 PSI max.
1,000 RPM input max.
Max output @ 1,000 RPM input: 40 GPM @ 2,000 PSI & 58.8 Hp input
Max output @ 540 RPM input: 21 GPM @ 2,000 PSI & 32.1 Hp input
You have to keep the rpm at max, for the figures quoted for the pump.
Is this a new pump? The pressure doesn't seem right. How did you set the system to measure the pressure.
Did you max out the cyl for the pressure reading?
What is the relief setting on the valve?
You should be able to run that pump with that
engine.
In order to get the volume and pressure, you need to change the ratios and use max engine rpm.
You are simply running out of HP at lower engine rpm. In the specs, you need 540 to get the 21 GPM's, but you should reduce the 3600 engine rpm down to the 540 or 1000 PTO rpm.
Your pump doesn't like the ratios, or the rpms.
Your highest pressure will be determined by the resistance to the fluid, and that is usually achieved
by holding the lever on the valve to full fwd or rev.
The relief valve will activate when doing this, now read the system pressure.
If you can't get the specified pressure, that means that the pump may be worn, or the relief on the valve is not set correctly.
Rpm's on the pump will dictate GPM's.
Using full HP on the engine, and a good pump, you should see 21 GPM at 540 rpm, and 40 GPM's at 1000 PTO speed.
Do you have a good return filter in the system?
What kind of valve are you using, and can it take the 21 and 40 GPM's?
You will have some fast times on the cyl.
For 1000 PTO rpm, you need a 3.6 ratio, and at 540 PTO rpm, you need a 6.66 ratio.
The pump is almost new....the problem is driving it.
(4) 3v5300's actually STOP at near 1100 psi with cylinder at end of stroke.
The D05 Vickers valve (open-center) is on a Damon subplate which has a max-2000psi relief in it.
When I said HP drops off....i meant the capability of the belts or even a chain (RC80 single) drops off...not the engine. The engine has plenty of HP....40 some at 1600. The belts smoke way before that.
I will try the chain.
The chain should deliver 25hp up to about 1200 rpm....then it looses capability.
The pump needs 23 for 1500 PSI and 32 for 2000 PSI.
The problem is delivering those Hp's to the pump via a jackshaft.
I guess I could use a truck-rear differential with a 3.0 ratio directly driven off the Wisonsin crank via coupling if the RC80 can't do it?
Sorry for confusion on the HP
   / PTO Pump driven with Jackshaft #4
Are you putting side load on the pump shaft? If yes you might to check to see that this pump is rated for side loads. Some are and some aren't.
Roy
   / PTO Pump driven with Jackshaft #5
Where are you getting the specs for the pressure. A pump is rated for the max pressure it can develop safely. If the pump manufacturer says it can develop 2000 psi, then that is what the pump will try to do, at any speed.
The specs for that pump is in post #2
The HP needed to run that pump is based on pressure and GPM's.
So from 1 rpm up to the max driven rpm, it is putting out potential pressure. That pressure is developed by the resistance to the flow. If you should happen to block off all pressure from the pump, the pressure will develop to 2000 psi or above, the pump , hose, other parts will probably self destruct.
If you use a valve to control the flow, and extend the cyl to max, the valve PRV will provide some pressure relief.
   / PTO Pump driven with Jackshaft #6
This is how I hooked mine up. Its right at 3 to 1 and my pump did have a side load that was somewher between 8 and 12 oclock. I made a chain adjuster and you might be able to see it, its a bolt that moves the pump.
   / PTO Pump driven with Jackshaft #7
About the only real way to measure the pressure and flow , is with a pressure gage and flow meter.
If you can only get 1100 or 1200 psi, then something is wrong. Pump is not working to specs, valve PRV set to 1100 psi, cyl leaking fluid internally.
If your pump can not develop the pressure, you can not measure and set the PRV.
Where is your hyd gage installed?
   / PTO Pump driven with Jackshaft #8
You mentioned subplates, are you using solenoid valves for the control, and if so, how do you have the cyl's timed to extend and return?
On the Q about side-loading:
No more than if it was on a PTO on a tractor. The Jackshaft is supported by 2 flange bearings on each side of the sheave. The PTO shaft simply sticks out with the pump slid on it, and then I have the outrigger to hold pump from trying to rotate.....same as if on a tractor.
The sheave base,bearings,etc are adjustable for steering & tensioning the belts (4).
On JJ's points:
The pump is a Prince HC-PTO-1A. The data I am going by is from Prince's data sheet. The pump is for 540 PTO RPM only (allowable over speed of 10%).
The one you mention is the Rear-ported is the HC-P-K11, which is not what I have.
Here are Princes Specs directly from their sheets:
HC-PTO-1A or HC-PTO-1AC (difference being Alum or Cast-Iron Center section)
540 RPM
8.4HP for 500 psi 21.4 gpm
16.1HP for 1000 psi 21.0 gpm
23.8HP for 1500 psi 21.0 gpm
32.1HP for 2000 psi 21.0 gpm
What you are not getting is that the 4 belts CANNOT deliver enough HP for the pump to put out over ~1000 psi....they slip.
I can run the engine to 1800 RPM as long as the GPM is going thru an open-center valve. But if I run the cylinder to either extreme in or out, I never get the relief to relieve (it IS a 2000 psi relief). The reason is not the pump. The pump STOPS because the belts are slipping/burning-up....kabish?
This occurs with gauge showing around 1100 psi while cylinder is fully extended or retracted or against a log,etc.
It's sorta like the irresistable force vs. the immovable object. The belts cannot deliver 23 or 32 HP and actually from some belt charts, I am surprised that they are delivering the HP to get to ~1000 psi.
The valve is a Vickers D05 series open-center...all ports. It is good for 25GPM.
The valve is on a subplate that has a cartridge Relief in it. It is adjustable to 2000 psi. This subplate has a P & T on both ends, just like a manifold. The extra P&T's had SAE plugs, but I put a gauge on the P. The other P goes to the pump. One T is plugged and one goes to the Tank.
Timing the cylinders?.....no idea what that means.
You mean with a stop-watch?
I can calculate speed OUT and speed in if need-be. But it is plenty fast both ways. That is not the problem.
Cub Cadet ZTT i1042 Lawn Mower (A53117)
Cub Cadet ZTT...
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
