PTO problems
/ PTO problems #1
streisel
Augusta, WV
Mahindra 2615
I have a 2615 Mahindra tractor. The PTO shaft is dropping out of the connection sleeve and I can not determine how it is happening.
It seems to happen when the tractor is facing uphill. When working with the front of the tractor below the rear, it seems works fine.
I have returned the shaft to its mooring once but it has somehow disengaged again. Considering placing a pin through the sleeve and the gear so that it cannot disengage.
/ PTO problems #4
It sounds as if you aren't fully engaging the coupler. When it is properly connected you should not be able to move the collar on the coupler without first disengaging it. I hear a distinct snap when it is fully connected. Go to the 5 minute mark in this video: Hooking up a Three Point Implement - YouTube
/ PTO problems #5
Charlie is that you? Aching Back is right, it sounds like your implement is not fully locked in. You may want to put a little grease on your tractor PTO shaft and some WD on your implement coupler and work the pin or collar until it works freely. Then reattach shaft until you hear a click and can't pull the shaft off of PTO.
/ PTO problems #6
It was Charlie, and he drilled a hole. Oh well it was an old post. :confused3:
2018 CASE 750M WT CRAWLER DOZER (A65056)
2018 CASE 750M WT...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
1996 DODGE RAM 1500 LARAMIE SLT EXTENDED CAB TRUCK (A65057)
1996 DODGE RAM...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2006 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2006 WINSTON...
