PTO override clutch
   / PTO override clutch #1
WHMOBX
Dayton, Maryland
1954 Ford NAA, 2004 New Holland TC 45 DA
Dumb question but, I need to remove the override clutch on my Ford NAA and I don't know how. I put the darn thing on about 6 years ago but I can't remember how it went on. I removed the set screw, but that didn't seem to do anything. Can someone shed a little light on my predicament. Thanks. Bill.
   / PTO override clutch #2
Yes, there is a pin which runs through the tractor's PTO shaft which holds the clutch on. Remove the zerk, rotate the clutch around until you can see the head of the pin, and then use a punch to hammer it out.
Thanks Joe, I didn't spend much time on it. I will punch the pin out first thing tomorrow. I'm going to use my NAA to spread fertilizer instead of my new NH. The pto shaft on the spreader will not fit with the coupler in place. Thanks again, Bill.
   / PTO override clutch #4
If you don't have a suitable punch, a 1/4" socket extention usually works good!
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
2004 Honda Accord Sedan (A51694)
2004 Honda Accord...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
