pto output shaft stopped working on ym 240
   / pto output shaft stopped working on ym 240 #1
homephysician
PELL CITY, ALABAMA
ym240
Hi I was mowing with my 6 ft. flail mower and the output shaft quit working. I was cutting over grown brush. I know I shouldn't but I was going very slow. My question is, is there a shear pin in the pto like in a 8n ford? Or is there something else internal thats broken? The tractor goes in all gears forward and reverse. The pto is a 2 speed unit and i get nothing in any position. Thanks in advance for your help, David
   / pto output shaft stopped working on ym 240 #2
there is certaintly NO shear pin on an 8n pto assembly ( shaft, bearing, seal, bearing carrier, wear ring, snap rings.. etc. )
Thanks for responding. On my 8n I broke a steel pin of some sort when bush hogging. I removed the grease fitting and the cap on the opposite side from the grease fitting and replaced the steel pin. Then it all went back together and it worked. Thanks, David
   / pto output shaft stopped working on ym 240 #4
you had an over running coupler that slips onto the tractor PTO shaft. it is held on by a roll pin, there are usually 2 plugs, or zerks that you line up to driv ethe pin in and out.
the ORC is NOT part of the tractor or pto assembly.
it's a attachment.. just like a mower. and it certaintly isn;t a shear pin. it's a coupler pin.
when i see a roll pin on a splined connection shear.. it's NOT fropm rotational play, unless the pto spline is wore SLAP out and the roll pin is takig the rotational load. but rather it is from THRUST forces.. IE.. when the telescoping pto shaft is TOO LONG and pushes onthe orc shearing the pin.
to the OP:
recheck.
take mower shaft off tractor pto and see if tractor pto is spinning. maybee it is soemthing inthe driveline for the mower.
also.. make sure you hav enot got it between pto ratios, and pto lever is engaged.
post back
   / pto output shaft stopped working on ym 240 #5
   / pto output shaft stopped working on ym 240 #6
Sent you a pm.
Hey thanks, I appreciate the pm. Very helpful. I got her going. Not sure what I did though. The lever for pto clicked in all 3 positions but nothing on output. Then I put it in reverse and it locked in. Its been working ever since. Thanks and really appreciated the download Winston.
   / pto output shaft stopped working on ym 240 #8
Don't know what you may have done either. But hey, if it worked good . I pass through PC from time to time going to a friend of mine's home on the river in Linclon
   / pto output shaft stopped working on ym 240 #9
that unit doesn't have an internal ORC does it?
   / pto output shaft stopped working on ym 240 #10
Yes, the 240 does have an internal over run clutch.
2003 SUZUKI VINSON 500 ATV QUAD RUNNER (A51247)
2003 SUZUKI VINSON...
2022 KMC 21-37-HD LOT IDENTIFIER 164 (A53084)
2022 KMC 21-37-HD...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
