PTO On/Off Lever
   / PTO On/Off Lever #1
bentonmike
Benton Ky
Kubota BX25
After reading about 100 threads about the stop solenoid (which I think mine is bad) I just have one question. Is there a seperate safety on the PTO lever, or does it work the stop solenoid? The reason I ask is the only way I can start my BX25 is to pull up on the PTO lever and turn the key. I've already got the stop solenoid unplugged, but it did this before then even. Sorry to be so long winded...any help would be great, just don't want to buy a stop solenoid if it's something else...Thanks again for a great site...Mike
   / PTO On/Off Lever #2
The Stop solenoid will pulse once and shut off an engine when 12 volts is removed at the key switch.
The safety interlock on the PTO is to prevent the starter from cranking the engine with the PTO engaged... (it's a N/C SPST switch in series with the start wiring, and it Is adjustable to some degree).
   / PTO On/Off Lever
Thanks for the quick reply! I'm guessing it's something to do with the switch on the PTO lever. Now I've got an avenue to look at...I'll keep you posted...Mike
   / PTO On/Off Lever
KennV do you know where I can find a picture of the PTO Safety switch? That would be a big help...thanks again. Mike
   / PTO On/Off Lever #6
Mike, you prob. just need to adjust the PTO switch a tad... on my BX24 it was almost as touchy as your tractor. The switch bracket has elongated mounting holes, just loosen the 2 screws, slide the switch just a bit, and tighten. Easier with the left rear wheel off.
Pete
   / PTO On/Off Lever
Thanks for the help guys. I'm going to try and adjust the switch next Monday. I'm off to Chicago for the weekend. I'll keep you guys posted...Mike
   / PTO On/Off Lever #8
Sometimes when I'm get off I sometimes brush against mine ,all it takes is a very light touch it'll shut off if running, or I have to pull up to start. I have a bx24.
Scag 36 Advantage Push Mower (A50121)
Scag 36 Advantage...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2017 Hyundai Tucson SUV (A50324)
2017 Hyundai...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
