3-Point Hitch PTO not turning on 1710
   / PTO not turning on 1710 #1
matt delfert
Rockbridge baths, VA and Holtwood, PA
1940 farmall M; 1985 Ford 1710 with loader
Purchased a used 1985 (now vintage?) 1710 with loader. Problem--the PTO does not turn when engaged. Moves slightly but will not turn with any resistance. It moves freely in either direction by hand even whe PTO lever is engaged. Loader works fine. Oil and filters recently changed. 3 pt hitch operates fine--its just the PTO. Any help here would be much appreciated.
   / PTO not turning on 1710 #2
Have an owners manual? It should have a procedure for adjusting the pressure plate fingers on the two-plate clutch. That first, then linkage adj for the main drive clutch, I believe. Your PTO clutch could be worn out, but you won't know until you try the adjustment.
Jim
2016 John Deere 6130M (A50120)
2016 John Deere...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
P.T 14' Disc Harrow (A50120)
P.T 14' Disc...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
