PTO Not Engaging
/ PTO Not Engaging #1
mczajicek5
Cub Cadet LT1042
I have a Cub Cadet LT1042 that's about 6 years old and just recently, the blades on my deck won't engage when I pull the PTO switch. I took the old switch out and replaced it with a new one. After about 3 tries the blades finally kicked on and worked fine. But, ironically, when I finished cutting the lawn it stopped again and now I can't get it going again. Any thoughts?
/ PTO Not Engaging #2
Yes, your problem sounds like a loose connector in the harness or a broken wire that is barely touching. If you have a voltmeter, you can verify power to the switch and power to the output side of the switch when you toggle it on. You can also use a 12 volt test light for this. My guess is that you have a connector somewhere at the opposite end of the wire near the PTO that is loose or broken. It's common to snag a wire with brush or it might just be a connector that was never fully engaged and has started making intermittent contact. I think if you follow the wires from the switch to the PTO you'll find your problem.
2022 EZ-GO ELITE...
3PT CARRY ALL (A63291)
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
