PTO Not Engaging
/ PTO Not Engaging #1
mczajicek5
Cub Cadet LT1042
I have a Cub Cadet LT1042 that's about 6 years old and just recently, the blades on my deck won't engage when I pull the PTO switch. I took the old switch out and replaced it with a new one. After about 3 tries the blades finally kicked on and worked fine. But, ironically, when I finished cutting the lawn it stopped again and now I can't get it going again. Any thoughts?
/ PTO Not Engaging #2
Yes, your problem sounds like a loose connector in the harness or a broken wire that is barely touching. If you have a voltmeter, you can verify power to the switch and power to the output side of the switch when you toggle it on. You can also use a 12 volt test light for this. My guess is that you have a connector somewhere at the opposite end of the wire near the PTO that is loose or broken. It's common to snag a wire with brush or it might just be a connector that was never fully engaged and has started making intermittent contact. I think if you follow the wires from the switch to the PTO you'll find your problem.
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
HARDEE 6' BOX BLADE (A63291)
HARDEE 6' BOX...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
John Deere XUV825E (A61307)
John Deere XUV825E...
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
