PTO not disengaging on 2520
   / PTO not disengaging on 2520 #11
Well as expected, mine has become MUCH worse. It now continues to run with a dangerous amount of power after shutting off the electric pto switch. It does not matter what procedure you use to turn it off (throttling down, or not). I can now, not even move the selector for mid/rear pto after shutting off the switch, as there is still too much power going to the pto.
With no load on the pto when engaged the engine rpms drop momentarily then continue along as they should with no load. HOWEVER when the pto is "disengaged" via the switch, the engine actually loads more so than it did with "no load". This leads me to think that the fluid is in fact leaking past a small orifice, creating this "restriction" to place a load on the engine.
The only way i have to deal with this right now, is to shut the tractor off completely. At this point the pto is not engaged, however as soon as the pto switch is engaged and disengaged, the problem is still there. Looks as if a shop manual and some wrench time is in order.
   / PTO not disengaging on 2520 #12
I would recommend checking out the section of the tech manual where they talk about testing the clutch circuit pressure. Seems fairly easy to get access to the test port, and that could verify that the solenoid is not shutting off the pressure correctly. Your latest description of the problem makes it sound even more like it's that solenoid getting stuck open after being energized.
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Sterling Acterra Service Truck, VIN # 2FZACFDC67AY51272 (A57453)
2007 Sterling...
