PTO Noise
/ PTO Noise #1
racechaser8
Piketon,OHIO
JD 300B & MT160D
I recently bought a mt160D problem is when drivin in any gear with pto in neutral it sounds like its tryin to kick in gear. not always but sometimes. what can be done to fix this ? thanks for the help !! racechaser8
/ PTO Noise #2
Undoubtedly you have 3 PTO speeds. 1 N 2 N 3
Behind the PTO speed lever is a plate that is attached to the tunnel.
The machine screw that holds it stationary to the tunnel when loosened allows the plate to be moved a bit in both directions and is actually the mechanism to adjust the positions of the selector.
Repositioning the plate will assure that Neutral is actually in a neutral location.
In all probability some slop has entered the equation over time and a minor adjustment is called for.
My MT180D needed that fine tuning as well.
And welcome to TBN.
/ PTO Noise
thanks for the info,when i get some more time i will try that ,thanks again. racechaser8
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
2022 EZ-GO ELITE...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
