PTO Mounted Wood Winch
/ PTO Mounted Wood Winch #1
Huntthomas
Mass
KUBOTA L2800DT
Hi, I am intrested in buying a wood winch to haul out my seasonal fire wood with my 29hp tractor. Anyone have any experiance with diffrent models ect? Thanks Tom
Wood Winch Info
Hi,
Just wondering if anyone has any info on a good non expensive wood winch?
I am in the process of looking for one for my L2800, to bring in my firewood for the winter. I have used them, but only on larger HP tractors? I go through about 10-12 cords a year to heat my home, I bring it out of the woods in tree lenghts all trimed, pile it up and start cutting, and splitting. Any info would be great. Thanks Tom
/ PTO Mounted Wood Winch #3
Vermeer makes a good one. They can pull an elephant thru a garden hose. You almost never see them on the used market either. Spendy too. But quality costs a bit more than mass market cra- from china.
/ PTO Mounted Wood Winch #6
Re: Wood Winch Info
Tom
If you search the forum you might find some members with experience with them. From what I understand, isn't it impossible to use non-expensive and wood/tree winch at the same time?
/ PTO Mounted Wood Winch #7
Re: Wood Winch Info
Non-expensive could mean one thing to me, being cheap, and another thing to some one else.
I have used a hand crank boat winch to pull longer lengths of fire wood to a place that can be driven to. I think that one cost me around $65.00. It was a dual speed unit that took a fair amount of cranking but got the job done. I suppose one could use a larger size cordless drill to replace the hand crank.
Others have used 12 volt winches Atv size and larger. Then there are the skidding winches made for a 3PH, I believe there is one which can be used on tractors under 30 hp.
I have a Farmi 3PH winch that has served me well for the past 26 years, it is on a 30 hp tractor and is still worth what I paid for it. So I guess even though it cost me $900.00 26 years ago it has been a relatively inexpensive tool. On average I have cut better than 12 full cord of wood a year plus skid out over 30,000 BF of logs and it's still pulling.
Randy
/ PTO Mounted Wood Winch #8
Huntthomas:
Another quality winch manufacturer is Tajfun. None of them are cheap. Jay
/ PTO Mounted Wood Winch #9
Re: Wood Winch Info
Huntthomas:
I do not believe that there are any good, but inexpensive wood winches available in the marketplace :(. Jay
1987 CAT D8N (A68134)
2006 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
Depth Band wheel, Scapers (A68191)
Depth Band wheel...
2005 MACK CHN613 (A67714)
2005 MACK CHN613...
