PTO Model 4035
   / PTO Model 4035 #1
ehoffmeyer
Mahindra 4035
Neither PTO control switch has any effect on stopping the pto shaft from running.
I even disconnected the 2 pin connector on the PTO control solenoid and the shaft continues to turn.
I sure could use some help figuring this one out.
Thank you.
PS
I now call this tractor the "Mahindrance"
Eric
   / PTO Model 4035 #2
Is it running with full power or just spinning from oil or clutch drag,
will it run an implement under load when shut off.
   / PTO Model 4035
Running with full power and it responds to increases and decreases in the hand throttle.
It acts like it is locked to the "on" position and I can't turn it off.
Thank you for responding!
Eric
   / PTO Model 4035 #4
ever find out what it was? must have been a short somewhere. did you try pulling the fuse?
   / PTO Model 4035
No. The electrical connection at the PTO solenoid is disconnected, pulled off not on the solenoid yet the PTO shaft continues to run at power/RPM levels commensurate with the throttle position.
Eric
   / PTO Model 4035 #6
Have you removed the actual solenoid valve not the coil but the actual valve,
it could be hung open.
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
PT Twin Drum Aerator (A50121)
PT Twin Drum...
1268 (A50490)
1268 (A50490)
John Deere 7130 (A50120)
John Deere 7130...
Stanley MB3570 Skidloader Breaker (A50774)
Stanley MB3570...
Army Semi Trailer (TITLE) (A50774)
Army Semi Trailer...
