PTO Log Splitter Project
/ PTO Log Splitter Project #11
Here is the hydraulic aggregate," used condition" I can remove the electric motor and put in a gearbox which I connect to the pto. The gearbox increases the speed of the pump, allowing the tractor to work at almost idle motor rpm, still plenty of power.
/ PTO Log Splitter Project #12
one more pic.
/ PTO Log Splitter Project #13
That's quite innovative! Someone once told me that electric motors are much more efficient that running a gasoline engine.
/ PTO Log Splitter Project #14
</font><font color="blue" class="small">( I'm taking my power of the Tractor's rear PTO (22hp) ....... That will be accomplished with a combination of an increasing gearbox and different sized pulleys. )</font>
IC.
If ya don't mind let us know what you come up with in terms of component parts on the gearbox and pulleys .... I've got a lawn/leaf vacuum that I would like to convert to PTO from gas ..... sounds like whatever you come up with might just work.
Well, despite losing Saturday to helping some geriatric members of the Wife's family clear out some of the clutter in their condo, construction is now underway. I cut and started to grind the gusset plates (4) today.
Because I want the gusset plates to fit quite snugly between the flanges of the H-beam even prior to welding (I will grind a bevel to help get good penetration) and am a bit new to the plasma cutter game (wasn't sure abuot how much "kerf" the cutter removed - but seems to be less than 1/8"), I purposely cut them just a bit (about 1/16") oversize and will grind them down bit by bit until they can be tapped into position with a rubber mallet.
May get at least the first two ground and placed tomorrow, prior to a few hours of business type work.
Once the gussets are welded in place, the next step will be to cut the end plates. Since these are intentionally cut a bit shorter than the distance between the outsides of the flanges in order to set up a fillet weld, these will not require as much grinding.
BTW, using a drill-driven "PG" (flap) wheel and/or 50 grit 3x21 belt sander for stripping down weld areas to bright metal. One thing that I learned from my Bh dolly project was that there is no such thing as a "too clean" weld joint area.
I'll get out the digital camera and try to post a couple of pics soon.
/ PTO Log Splitter Project #16
Hi Mad Dog,
You should've took the BX into the condo, It would have moved something fast /forums/images/graemlins/grin.gif like the inlaw out of there.
I have a few questions for you, since I'm into the same project as you right now.
I've pick up a 2-stages 22GPM, since it's rated for a 16HP. My thinking is that the PTO is reated on my BX22 at 16HP. Could I had gone bigger like you at 28GPM?
I was thinking os using an old Rear mower for speeding up my pump. Since the gear box & pulley should bring me easy at 3200RPM, is this the right RPM?
Any help would be great, since I'm new at this hydraulic.
Bird
Bird, I'm pretty knew at it, too, so I'm afraid it's gonna be a case of the blind leading the blind. /forums/images/graemlins/wink.gif
However, here's a crack at responding.
I calculated the Barnes 28 gpm 2-stage at drawing something in the 16-17hp range so I think that you'd be OK with it, but doubt that you need it unless you are building a huge splitter. I'm using a 5" bore cylinder and, even with it, I think you can probably get a pretty decent cycle time with the 22gpm pump. It isn't hard to calculate, just figure 5.5gpm at high pressure and 22 gpm at low; and estimate, depending on the kind and size wood you will be splitting, how much of an average stroke will be at each. Then take 231 cu. in /gal for the area of whatever size cylinder you are going to use. For the return cycle, just reduce the bore area by the area of the rod and take the cycle speed at low pressure all the way.
As for the pump speed, I think that the Barnes 2 stage pumps are spec'd to run at up to 4000rpm and I was planning to run mine at about 3500. I think that 3200 is probably adequate to give you reasonable performance, but I'm not knowledgeable enough for that to be more than a hunch.
It isn't hard to take an increasing gearbox and some pulleys to get the speed up to 3500 or so. Surplus Center has a gear increasing box that will take your 540 pto rpm up to about 1025 and using a 9.75" double groove pulley on the gearbox output and running it to a 2.75" pulley on a jackshaft connected to the pump should give you plenty of rpm even at a bit less than full pto speed.
BTWm what kind of valve and what size reservoir are you going to use. For the 22gpm barns pump you probably want at least a 20gal reservoir. The www.baileynet.com online catalogue has some good ones, as does surpluscenter.com.
Surplus center also has some nice autocycle valves.
Hope this helps.
/ PTO Log Splitter Project #18
How's it coming?
Hi cp: It's coming pretty slow, because I have spent the last two weekends with wife and SIL cleaning out their elderly aunt and uncle's condo, which was in a state of clutter that was way past "appalling" and had gotten to "inconceivable."
I have taken four truckloads of crap that they "just can't part with" to storage and have discarded about 20 outdoor sized trash bags of refuse and we're still only about 1/3 of the way there. The funniest part was when I had finally excavated my way to a corner of uncle-in-law's bedroom. Sitting there was a can of "Pledge" dusting spray, up to its nozzle in dust.
...but I digress. I cut the gusset plates before we learned of this mess and I am hoping to finish grinding and welding them this weekend. I'll keep you posted. (on the splitter project, not the "mess") /forums/images/graemlins/grin.gif
/ PTO Log Splitter Project #20
LOL, many of us have been there.
CFG Industrial MH12RX (A60463)
CFG Industrial...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
203201 (A60429)
203201 (A60429)
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
KJ K4020 40'x20' Carport Shed (A60463)
KJ K4020 40'x20'...
