PTO - live and learn
/ PTO - live and learn #1
Roadworthy
Elite Member
Southeast Washington
Kubota L2501 HST,
I did something stupid but perhaps I can spare someone else from my fate. I connected my mower PTO shaft but apparently it didn't lock into place properly. I got the mower spinning but the shaft slipped out of place dropping onto the mowing deck and flopping around while the blade slowed down. Okay, no biggie, just reconnect and move on. In the process it dented the PTO shaft and it would no longer smoothly slide in and out. A new PTO shaft would be in excess of $300 so I decided to purchase both halves of the shaft and replace the damaged shaft. I was able to score both sections locally for just over a hundred dollars but I got the last ones in town. The vendor doesn't know when he can get more. I think I'll rig some kind of strap to prevent the shaft from free falling in the future.
/ PTO - live and learn #3
Save the old shaft. You never know when you may need a short piece of shaft.
/ PTO - live and learn #4
how dented is the shaft. doesn't take much raised material to keep the halves from sliding together. you might be able to fix the shaft and have a spare.
/ PTO - live and learn #5
Agreed. If it's near the join point, perhaps you can trim off the damage and slide the remaining, but slightly shorter shaft back together
/ PTO - live and learn #7
If it's not too bad a dent possibly drill a small hole opposite the dent and use a small drift to tap the dent out?......
