PTO link system
/ PTO link system #1
Texastwist
John Deere 5210
Anyone have any experience with the PTO link system? kind of expensive. Is it worth the money? Other thoughts on attaching PTO attachments to make the job easier.
/ PTO link system #2
Personally, I'm not a fan of anything that extends the PTO shaft further than it needs to be. Just creates sharper angles on the PTO shaft, more wobble, more run out, harder on bearings, seals, etc. Eventually it will get wear, which will only make it worse.
A simple "trick" that works very well to get the PTO shafts on the shaft of the tractor is to align the splines and just slide the PTO shaft like 1/2" to 5/8" over the shaft on the tractor side.
Once the shaft is already started on the tractor side, you're not holding the weight of the PTO shaft anymore. So you can now worry about pressing the pin or pulling the collar and slide the shaft all the way in.
/ PTO link system #3
PTO shafts are pretty easy IF the shaft itself has been greased and slides in and out freely.
/ PTO link system #4
I spray mine down with Kearney Rust Cutter. Some of the best stuff I've ever used.
/ PTO link system #5
I looked at that PTO Link. For me I would have to have a setup for 7 or 8 PTO shafts. Doesn't make sense to spend that insane amount of money. And besides you still have to hook it up. It doesn't do it for you. Plus what ptsg said.
/ PTO link system #6
Back when I was a lineman I used to use Kearney rust cutter on just about everything on the pole, your right good stuff.
/ PTO link system #7
Power plant is where I discovered it. I keep it all the time now. It's expensive but well worth the money.
/ PTO link system #8
I've never heard of a PTO link system. What is it? PTOs always seemed to work just fine as is - not counting a few pinched fingers.... What am I missing?
/ PTO link system #9
I use a PTO quick connect. Yes it was not cheap but I feel it's much easier to connect than a standard PTO shaft. Been using it for 200 hrs of mowing - so far no sign of wear or ?
/ PTO link system #10
When doing a PTO hook up - I support the weight of the shaft with a bungee chord. Takes one factor out of the hook up equation.
/ PTO link system #11
I have the pto link. It's ok, you still have to hook up the shaft. I've only used it a couple times, seems to get easier as I use it more.
/ PTO link system #12
I am not sure that the PTO Link is worth the money. The main problems with hooking up a PTO is
* alignment of the pto splines
* weight of the PTO driveline
* Difficulty in holding latch back on PTO lock
PTO Link
* Has 4 holes making rotation 45 degrees max vs 30 degrees for a 6 spline
* adds additional weight to PTO driveline
* has an easier locking mechanism.
PTO link extends the PTO on the tractor beyond the guarding creating a hazard. It also requires up to 15 degrees more rotation of driveline to hook up. This makes hooking up implements more challenging.
I hate the collar lock type of coupler the squeezing action of pulling the collar back while trying to push the pto driveline on is terrible. Pin style couplers are my preferred method. There are some styles of collar lock that will lock back when pulled free of implement and slide forward when the shaft is inserted into the driveline. Weasler calls theirs Auto Lok. They are great when they work but if they get gummed up its a $%^& to hook them up.
Below is pin style (photos borrowed from Weasler)
Below is collar lock style
To hook up I will slide the driveline onto the tractor PTO then depress lock and slide the rest of the way on.
PTSG has great thoughts on the Bungee
I have hooked up drivelines on a variety of equipment, from small category 1 spreaders to large CV's on square balers. In my opinion the PTO link introduces more problems than it solves. It appears to be a well built durable unit.
PORTA POTTY (A68842)
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
1998 GMC SIERRA 1500 (A67714)
1998 GMC SIERRA...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
