PTO Link Easy PTO Adapter
/ PTO Link Easy PTO Adapter #21
I have serious arthritis and a weak right hand so that is exactly my problem too.
I really do wonder if anyone has actually used this adaptor.
I think I would really want return privileges for at least 90 days if I ever bought this...
I have the same problem. I have a PHD on my Kioti that I can t get off because I dont have the hand strength to work the push pin PTO in the tight space they give you. I even had my wife pull while I held the pin in and pulled. No dice. I think Ill have to take the PTO shaft apart to get it off. I don't want to go through this the next time I dig a post hole. Has anyone actually tried the PTO quick Link?
/ PTO Link Easy PTO Adapter #22
Anybody compare this with the John Deere Quik-Knect? The JD unit is good for any machine, any implement and once adapted, no aligning or such.
Don't have one myself, but hoping some JD folks do.
Anyone got some first hand info? Thanks.
/ PTO Link Easy PTO Adapter #23
I was comparing them too, assumed JD bought out the PTO Link people but their website is still up.
Are these adapters identical and if not, what is different? Other than the color...
just seems like a great idea. JD is also the only one, I believe, that has a quick connect for a belly mower.
/ PTO Link Easy PTO Adapter #24
If you check them closely the JD one is considerably more compact and doesn't add much to the overall length of the pto shaft. The JD one is also a replacement female yoke.
/ PTO Link Easy PTO Adapter #25
The PTO Link adapter adds about four of inches in length to any attached PTO shaft.
If you use Pat's Easy Change 3-point Hitch System, the hooks add about four inches in length to the two lifting arms.
If you use *both* the PTO Link and Pat's, the two effectively match lengths, negating any concerns of possibly needing to trim the length of a PTO shaft. Extend your top link a few inches (e.g. unscrew or hydro) to meet the implement, and you're good to go.
I believe my dealer did me a favor by cutting the PTO shaft that came with a rotary cutter that I bought with the tractor. I asked for the slip clutch option on the cutter. The dealer may have thought the slip clutch inserted into the drive line required the total length to be reduced. In any event, the tractor and cutter worked great. A couple weeks later, I added the Pat's Easy Change system, and discovered the PTO shaft wasn't long enough. The extra four inches that Pat's added to the overall length was too far for the drive line at its longest point. Options were now to either replace the drive line and guard, or add several inches in length to the PTO connection. This helped my decision to buy the PTO Link, as it added a few inches to the PTO connection.
See attached photos.
Don't throws rocks, I'll add the plastic PTO guard before going back into operation. Photos were taken without the guard to show the PTO Link, Pat's Easy Change, and the drive line components. I've also ordered new drive line inside and outside tubes, and a longer PTO guard, to replace the cut items. I suspect there's only about 4-inches of tube overlap after the dealer cut the line, which is working thus far, but I'd prefer more overlap.
Additional comments:
The PTO Link has two pins, one on top of the disc, and one on the bottom of the disc. Using both pins, the coupling appears to be equally as tight compared to traditional PTO couplers. One pin is permanently attached (but replaceable) on the tractor-side disc. The second pin you insert at time of implement hook-up, from the tractor-side. Replacements for both pins are available (I ordered a set with the kit; stow those away in the tractor toolbox like shear pins, etc.).
Additionally, the PTO Link has four cut-outs and large metal tabs that inter-connect the two discs. These cut-outs and tabs are what handle the workload of the spinning PTO shaft. The two pins are safety devices to keep the discs tightly coupled, but the pins don't carry the full power of the PTO. If a PTO shaft is spinning, it's not going to come out of those cut-outs, even if both pins failed. The design looks relatively safe; belt-and-suspenders style protections. I suspect if both pins failed, and you stopped and restarted the PTO several times, and you were driving on rough terrain, the coupling could separate if bounced around just right, probably when the PTO was off or just starting, where the shaft would then drop into the dirt. That's a lot to break, not a single point of failure.
The PTO Link installs out of the box in less than a minute, as it attaches on top of your current PTO spindle at the tractor, and into the existing coller for your implement. Because the PTO Link attaches on top of the existing tractor and implement PTO connection points, it's a universal adapter that can be used with just about any implement, made by any company.
The John Deere solution is different, as it replaces the coupler on the implement PTO end, which is why the JD solution is limited to implements made by specific companies, and why the JD solution adds less length to the overall PTO connection.
The PTO Link connectors can be quickly changed, moving across multiple implements (e.g. cutter, tiller, post hole digger, etc.) and tractors, so you really don't need more than one pair of connectors. Buying extra connectors provides the luxury of keeping the connectors always-on the tractor and implements, allowing your lazy side to win.
The JD solution attaches to the implement as a new yoke, replacing the connection end. You are better off buying an adapter to connect each implement you own, otherwise you'll be doing a lot more work in swapping it around. I view buying extra connectors with the JD solution as mandatory for those with multiple PTO implements. This is best limited to tractor owners who have implements that are documented as compatible with the JD solution. Note, the JD solution works with any tractor, but it is limited in which implements are compatible because it replaces the implement-side coupler.
Price?
The PTO Link isn't cheap, starting at ~$400. If you want an easier/alternative PTO hook-up process, and/or if you need to add a few inches in length to your PTO connection to ensure Pat's Easy Change doesn't require shortening drive lines, then the PTO Link is a good value. The JD solution costs about the same, starting at ~$465.
Final thoughts:
There's nothing wrong with using your tractor the way it's always been used. If you've got no issue with the standard PTO connection method, don't spend money on the new widgets.
The PTO Link is an interesting innovation, and it's priced about the same as the JD solution.
If you have JD-compatible implements, the JD solution provides similar improvements to the hook-up process, trading the need to buy multiple implement-side attachments to avoid adding a few inches to the overall length.
Where several companies are putting effort into a product area, there's a market need to fill.
PTO Link = Products Archive - Tractor PTO Link
JD Quik-Knect = John Deere Quik-Knect Tractor Receiver Kit - BLV1953
Another way to do it = Pto Connect – Tractor Add Ons LLC
/ PTO Link Easy PTO Adapter #26
After living with the PTO Link for more than a year, I'm not convinced there's a big improvement. Maybe I'm saving time with implement connections, but it can still be frustrating either way... Using the PTO Link, or using the standard tractor PTO shaft coupler, effort remains needed, and best to keep everything clean. The metal buttons/pins are hard to work in the cold, when dirty, and with old hands.
/ PTO Link Easy PTO Adapter #27
Like kthompson - my M6040 came with a protective sleeve on the PTO stub. Keeps it clean and greased. Patience is the cure for difficult PTO connections.
/ PTO Link Easy PTO Adapter #28
I've replaced most of my pto connection springs with lighter ones. On the collar type you remove a snap ring and the spring is behind the collar. The push button style usually has a circlip that holds the pin in. Lighter springs in both styles make life a lot easier. Just make sure that the pto locking mechanism is engaged in the grove in the tractor pto shaft.
/ PTO Link Easy PTO Adapter #29
Maybe this style of yoke, where the pin stays latched in, could be helpful for some you.
/ PTO Link Easy PTO Adapter #30
I use a sleeve that fits the tractor's male shaft to keep the groves clean and will wipe grease on them often when installing the sleeve back on, that helps a lot for me. That along with keeping the pto shafts out the dirt and lube normally I have no problem unless just boom mower and that is another story.
This attachment I agree is very costly and it also requires you to check each pto shaft to be sure length is not too long with it.
I've never really had an issue with PTO connectors either. My old tractor doesn't have any kind of cover on it, but I keep a thin film of grease on it as well as the female ends of the PTO shafts. If the stub on the tractor gets a little dirty a wire brush and some WD-40 cleans it up very quickly.
One thing about their quick coupler, it's going to add a few inches to total PTO shaft length. I have a flail mower and more particularly, a rototiller that are close connected to the tractor. It would require trimming the length of the PTO more than I would want. It would also require a shaft end coupler end for every PTO driven implement you own.
/ PTO Link Easy PTO Adapter #31
Agree totally and don't use grease on the telescoping part or the pto shaft. I just use WD-40. If I use grease it doesn't lake long and everything is hard to move from the dust and dirt. WD-40 isn't really enough of a lubricant but none of my shafts are going to wear out in my lifetime.
/ PTO Link Easy PTO Adapter #32
My trick also!
I spray my PTO coupler and shaft with WD40 and that cleans and flushes both just nicely.
Must be 8-10 years doing that and never an issue.
Oil or grease would simply retain sand and/or grit while WD flushes and leaves a simple protective coating.
/ PTO Link Easy PTO Adapter #33
Agree with your post totally but saw a youtuber (thing Good Tractor Works) mention the quick connect pto and pointed out it is a help to offset the quick connect hitches many people use. So maybe they would equal out each other. But I don't use a quick connect 3 pth either but really do like my telescoping lift arms.
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
KMC Strip Till Rig & Planters (A64126)
KMC Strip Till Rig...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
Well Tank (A64127)
Well Tank (A64127)
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
