PTO Lever Stuck ZD 321
   / PTO Lever Stuck ZD 321 #1
RTJ49
Kubota BX 25 & DZ 323
Hi All,
My zero turn ZD 323 will not let the mower/blades disengage. The lever will not move up and over to go back. Blades keep turning. Any help/ideas before I dig in?
Thanks,
RTJ49
   / PTO Lever Stuck ZD 321 #2
I got nothing. How did it turn out?
The linkage is light weight steel. It wants to flex a little to much. It seems to have never been greased. A little grease and a little force on the linkage seems to have done the trick. There is no grease fitting/zerk. You have to take the linkage apart and lube.
   / PTO Lever Stuck ZD 321 #4
Hi RTJ49, I seem to have the same issue with my ZD326S. PTO lever stuck mid-way. Do you actually have to take the linkages apart? I've read about a lever upgrade kit, have you tried any other solutions? Thanks!
Hi AGroG,
Sorry it has been so long. I still live with the problem. It seems to come and go. I wish I new of the lever upgrade kit, if there is such an item.
Thanks,
RTJ49
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
WOODS RT48.30 LOT NUMBER 234 (A53084)
WOODS RT48.30 LOT...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
