PTO Lever Stuck ZD 321
   / PTO Lever Stuck ZD 321 #1
RTJ49
Kubota BX 25 & DZ 323
Hi All,
My zero turn ZD 323 will not let the mower/blades disengage. The lever will not move up and over to go back. Blades keep turning. Any help/ideas before I dig in?
Thanks,
RTJ49
   / PTO Lever Stuck ZD 321 #2
I got nothing. How did it turn out?
The linkage is light weight steel. It wants to flex a little to much. It seems to have never been greased. A little grease and a little force on the linkage seems to have done the trick. There is no grease fitting/zerk. You have to take the linkage apart and lube.
   / PTO Lever Stuck ZD 321 #4
Hi RTJ49, I seem to have the same issue with my ZD326S. PTO lever stuck mid-way. Do you actually have to take the linkages apart? I've read about a lever upgrade kit, have you tried any other solutions? Thanks!
Hi AGroG,
Sorry it has been so long. I still live with the problem. It seems to come and go. I wish I new of the lever upgrade kit, if there is such an item.
Thanks,
RTJ49
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
