PTO lever on 1700
   / PTO lever on 1700 #1
sirgknight
South Georgia
Early model YM1700
Am I the only one who has a problem reaching the pto lever while riding the tractor? I am unable to lean over and reach the lever to either pull it up or push it down for engaging and disengaging. Has anyone come up with an "extension" handle or lever to assist in reaching the pto lever. I have to engage my pto before seating myself and disengage it after stepping down and I'm not real comfortable with performing the task in this manner. Any suggestions?
   / PTO lever on 1700 #2
sirgknight,
How long is your PTO lever? I am a sizable guy (6',250 lbs) and I do not have trouble reaching down to engage/disengage mine. If I am sitting on the tractor; my PTO lever is just behind my left ankle. I don't even have to look down to do it; just reach down and grab.
Fig
   / PTO lever on 1700 #4
I had the same issue on my 1810, I got very good a heal/toe that lever.
   / PTO lever on 1700 #5
The shift knob should be near your left ankle, and easy to reach.
Maybe the rebuilder left off the shift lever (#29 in the parts diagram) ??
   / PTO lever on 1700
Yes, the lever is present and it is located behind my left ankle, but it is so low (or seat is so high) that I can't bend over and grab the lever. I can get my middle and third finger to reach half way around it but can't get a good enough grip to pull or push it completely in/out of gear. Being 5' 10" and 300 lbs, I know I need to lose weight. Being fat doesn't help in anything I do, but the problem needs a quicker remedy over losing 100 lbs. I'm seriously thinking about developing myself a handle with a Y on the end that I can attach to the end of the pto lever. This way, when I sit on the tractor I can either push the lever down with the handle of pull the lever up with the handle. It will simply stay permanently attached as a T extension. I'm still working on that idea. Thanks for the input though.
   / PTO lever on 1700
i finally got my camera working. here's a pic that will show my lever. it sits too far down for me to bend over and reach.
   / PTO lever on 1700 #8
sirgknight,
Not a bad idea. Sort of like a "jockey shift" PTO lever /forums/images/graemlins/grin.gif. Make them for motorcycles and ATVs; why not a Yanmar.
Fig
   / PTO lever on 1700
yeah, that's the idea if I can make it work.
   / PTO lever on 1700 #10
Sounds like that would work just fine. Either that or add an extension to the existing lever and bend it upwards?
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2015 Chevrolet Cruze Sedan (A50324)
2015 Chevrolet...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
NEW Fork Extensions (A53002)
NEW Fork...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
