PTO lever/.Ford 340A --Ignition
   / PTO lever/.Ford 340A --Ignition #1
Grey Mountain
Anadarko, Oklahoma
Ford 8N, Ford 340A
The PTO engages sporadically when the lever is moved to the "ON" position. Must be loose connection, right? This just started to happen.
Gear must be in neutral for the tractor to start. At times, I just get a click. I can wiggle the gear shift and make the connection. Another loose connection somewhere? This has been going on for quite some time.
Suggestions?
GM
   / PTO lever/.Ford 340A --Ignition #2
The tractor is definitely old enough for switches to be failing but some of the connectors could be corroded, too. You could try pulling connectors and cleaning or tightening them.
OK. That was my thought as well. Just gotta find the connections... ;-)
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
