PTO kicking out of gear
   / PTO kicking out of gear #1
lg_mouth
Racine, Ohio
Kubota B7100
I am a newbie tractor owner and was trying to mow yesterday with my finish mower, but it wouldn't stay in second gear. It would run for about 20 seconds, then kick itself into N. It would run in 1st, but it would kick itself out of 2nd whenever I tried to use it. Any explanations? Am I just not doing something right? Thanks for the help.
Lg_mouth
   / PTO kicking out of gear #2
Your subject line says the PTO is kicking out but it sounds like the transmission is kicking out of 2nd. It that an HST or manual transmission B7100?
No, the tractor will continue to drive, but the PTO kicks into N and stops spinning.
It is the manuel transmission.
lg_mouth
   / PTO kicking out of gear #4
So the PTO kicks out in 2nd gear. Hmm. I don't think your doing anything wrong. I would check the linkage to see that it is engaging all the way. Beyond that I would not know. There are quite a few sharp people on this board though, someone may have experience with that and reply.
   / PTO kicking out of gear #5
I think he means that the 2nd speed of the pto is kicking out. The B7100 has a 3 speed pto. I'm not sure what could cause this, maybe a worn gear. I have a parts B7100, if you need parts give me a shout.
amitysanimal
Yeah, that is what is happening.
The handle is very loose and doesn't feel like it is seating in when I put it in 2nd or 3rd speed. First is all the way back, so it feels like it gets in when I put it in first. It runs fine in first as well.
Thanks for the offer. I will have to have someone look at it to tell me what is wrong. I barely have learned to operate the thing properly, much less work on it!
Thanks for the replies.
Lg_mouth
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2008 KOMATSU WA450-6 WHEEL LOADER (A51246)
2008 KOMATSU...
TOSHIBA 8000 BTU WINDOW AC UNIT (A51248)
TOSHIBA 8000 BTU...
BESTWAY LOT IDENTIFIER 19 (A53084)
BESTWAY LOT...
