PTO In Gear All Of The Time
   / PTO In Gear All Of The Time #1
IHUNT
Bangor, Maine Area
Does any one know how to fix a PTO that always turns. Even when I disengauge The PTO. I own a L3400 HST.
   / PTO In Gear All Of The Time #2
Have you checked the linkage? Is it turning and powering an implement? The reason I ask is that on some tractors the rear PTO shaft will rotate slowly even when not engaged, but have no power.
   / PTO In Gear All Of The Time #3
The PTO lever operates a cable that goes to the transmission to engage/disengage the PTO. When my L4610 was new, the lever at the transmission end of the cable kept slipping so the PTO would not disengage... just like yours. Dealer repaired it at no cost and it has been trouble free ever since. Your L3400 is probably similar... you should be able to see the linkage from underneath.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
