PTO hydraulic leak
/ PTO hydraulic leak #1
anthonyk
houston texas
Century 3647
I just went out to use my Century 3647 and noticed that the 3 point hitch wouldn't lift.
After some poking around I realized that there had been a slow leak from around the pto area and the hydraulic level was way down.
I refilled it and all was fine, but now I've obviously got to find the leak and correct it.
Has anyone ever encountered a similar problem, and if so, how much work was involved in repairing it?
I'm hoping it'll just be a seal or gasket, but I'm not sure if i should tackle this myself or take it to the dealership (about 30 miles away).
Any tips or advice would be appreciated as always,
anthony
/ PTO hydraulic leak #2
well before u jump the gun. u should clean the area of the leak and find where the problem is and how severe.seals do leak ,how much is the question.if it is just a drip a hour can u live with it.if it is a trickle u have to fix.if something is cracked u may have a costly repair.
/ PTO hydraulic leak #3
I thought I had a PTO seal leak back there. It turned out to be a loose vent cap. Fortunately, I lost just enough fluid to make a mess, but no other problems.
On mine, that curved thingy is the vent.
Do you mean you actually had hydraulic fluid leaking from around that rubber plug?
I don't think that's where it's coming from, but I'll check.
I'll be out there today, wiping everything down and trying to see where it might be coming from.
It's very slow, but annoying.
thanks,
anthony
/ PTO hydraulic leak #5
Apparently. It was loose. There was some fluid below it and more further down, and after I tightened it, it stopped.
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2013 Freightliner Cascadia (A68134)
2013 Freightliner...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
