PTO HP L5460 VS. L6060 I need some advice?
/ PTO HP L5460 VS. L6060 I need some advice? #22
/ PTO HP L5460 VS. L6060 I need some advice? #23
I have the same check valve kit he has..... but the problem is that with the side link that Kubota uses, the distance between the 2 ports is too short to fit the check valve into. Very frustrating.
Curious, for which tractor, the L4060?
/ PTO HP L5460 VS. L6060 I need some advice? #24
Its for my GL4060
Here is a pic of the side link with the checkvalve on top. I dont see a way that with the banjo bolts installed that it will ever fit.
I am thinking about modifying the extra toplink in the picture to make it a side link.
/ PTO HP L5460 VS. L6060 I need some advice? #25
That's the problem with the 4" stroke cylinders. Simply not enough room to get a DPOCV installed in line. You could get a bunch of fittings and get it mounted off to the side. Your tractor really should have a 5" stroke cylinder for everything to be just right.
I think that if you go with the top link that you have and modify , at best it will be level when fully retracted and a very steep angle when fully extended. There are suppliers that build to be level when fully retracted, but that limits the capabilities of the machine unless you go with 2 hyd side links.
Good luck with your endeavor. :thumbsup:
/ PTO HP L5460 VS. L6060 I need some advice? #26
Thanks!
I may yet place my side link order with you and get on the waiting list!
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
WATER TRAILER (A58214)
