Backhoe PTO HP for a Backhoe PTO pump
   / PTO HP for a Backhoe PTO pump #1
d1000
Southern Maryland
Kubota L185 and L225; Cub Cadet 1872
I just bought a Prairie Dog Backhoe that came with the PTO pump and Reservoir via an auction. Manuals are supposed to be in the mail. The hoe is recommended for tractors with 20-40 HP. Does the PTO pump really require 20+HP to be effective, or is the 20-40 HP only necessary when using the tractor hydraulics? The reason for asking is that I'm thinking of mounting the hoe onto my L185 as a "permanent" install, but this only has 15 PTO HP. This would leave the L225 available for the rest of my attachments.
Thanks,
Dave
   / PTO HP for a Backhoe PTO pump #2
I would expect you would be alright. I have an L1801DT with a backhoe on it plumbed off tractor hydraulics that works good(would prefer pto pump) . If you do not have a FEL on the tractor you might want to rethink it. Also what is the weight of the backhoe, L185 manual says 800#'s with a subframe.
Thanks. Both the L185 and L225 have Kubota FELs; an L1200 and an L1700, respectively. As to weight, I'll know more after I get the manual for the Praire Dog, but it may be > 900#. Sounds like that could (will) be an issue. By the way, I'll have to make a subframe assembly since one doesn't seem to be commercially available for my older Kubotas.
2014 Chevrolet Silverado 4x4 Pickup Truck, VIN # 1GC1KXEG9EF156183 (A51572)
2014 Chevrolet...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
1275 (A50490)
1275 (A50490)
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
20ft Shipping Container (A51573)
20ft Shipping...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
