PTO hard to engage and grinding
   / PTO hard to engage and grinding #1
blaze 57
John Deere 870 the PTO is becoming gradually harder to engage. Is there an adjustment?...Does the clutch adjustment rod have something to do with it? Thanks
   / PTO hard to engage and grinding #2
If you have a dual stage clutch, it's probably a clutch adjustment.
Yes Roy, its dual clutch. I did find the nut adjustment on a threaded rod where it goes into the clutch area...I'll try adjusting that. The tractor has over 2,000 hrs and I've never adjusted this area since new in 94' thanks.
   / PTO hard to engage and grinding #4
Follow your manual. Not all adjustments are the same, or done in the same order
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
