PTO hard to engage and grinding
   / PTO hard to engage and grinding #1
blaze 57
Bronze Member
John Deere 870 the PTO is becoming gradually harder to engage. Is there an adjustment?...Does the clutch adjustment rod have something to do with it? Thanks
   / PTO hard to engage and grinding #2
If you have a dual stage clutch, it's probably a clutch adjustment.
Yes Roy, its dual clutch. I did find the nut adjustment on a threaded rod where it goes into the clutch area...I'll try adjusting that. The tractor has over 2,000 hrs and I've never adjusted this area since new in 94' thanks.
   / PTO hard to engage and grinding #4
Follow your manual. Not all adjustments are the same, or done in the same order
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
2015 PETERBILT 579 (A53843)
2015 PETERBILT 579...
2002 MACK CH613 (A53843)
2002 MACK CH613...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
