pto grinding
   / pto grinding #1
snikers01
2003 new holland tc 33
I have a 03 tc33 tractor, i try to shift to mid mound pto it grinds. there is not adjustment on the lever what is the cure?
   / pto grinding #2
I am assuming you have a gear drive (9 speed) tractor which has a 2 position clutch. Half way down stops forward motion and fully depressed disengages the pto(s). It is possible for the pto clutch to be rusted or stuck to the plate and not disengaging (lack of use). A possible cure would be to attach a pto driven implement (rear or mid), engage the pto with the tractor OFF. depress the clutch fully and start the tractor. You will probably have to override the safety circuits with a jumper to start with the pto engaged. good luck!
   / pto grinding
I have a hydro trans this would be my mid mount PTO
   / pto grinding #4
Not to be condescending, you are depressing the clutch petal before you engage the PTO lever?
   / pto grinding
yes even if I hold it in for a few seconds still grinds
   / pto grinding #6
Another similar posting said: "The screw that is a stop for the clutch pedal had worked it way out not letting me push the clutch in all the way. Screwed it in some more and now works great."
   / pto grinding #7
To the OP....If you are in gear and the hydro peddle is being pressed so you are moving, will your clutch peddle stop your movement?
   / pto grinding
Yes it will stop me it works "normal" in every other respect.
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
Electric Concrete Mixer (A51573)
Electric Concrete...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
