pto grinding
   / pto grinding #1
pault160
Skiatook
mahindra 7520
Hello all , Im new here , but have read some great info on this site. I have an issue with a 7520 pto engagement. I bought the tractor with 392 hours on the meter. when I connected a sprayer pump to fight some fire , the pto worked fine. Today I hooked up my brush hog and engaged the pto and got an awful grinding or ratcheting sound. I pulled the shaft and turned it to the 1000 rpm shaft and felt that the gears werent engaging correctly. The rear end looks like its been gone into before , and I have not contacted the dealer as of yet. Does anyone know if there is a problem with this system? Should it be covered under warranty? Its a 2009 model with 427 hours. My tractor does not have the pto on/off lever , just the pto engagement lever. Any info or ideas would help a lot. Thanks.
   / pto grinding #2
Your tractor probably has a dual foot clutch... and is probably in need of adjustment. Check your owners manual, it should outline the process. You should also engage/disengage the PTO at low RPM whenever possible. Since it is a used tractor, you don't know how the previous operator abused it... Hopefully... the clutch adjustment is all you need..... :)
   / pto grinding #3
7520s have a pto clutch lever that you throw before engaging the pto. After pto gear is engaged, you release the pto clutch lever to start the output stub.
larry
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50323)
2006 Imperial 14Ft...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
