PTO Generators: Winco
   / PTO Generators: Winco #2
Been using a Winco 25kw PTO generator since Y2K. Love it. With my Ford 601, the gas engine would cough and regulating voltage was a bit of a challenge. When the electric water heater came on, had to adjust the throttle up. Now I've traded up to a Branson 3510 and the 35 hp diesel stays right at the voltage I set.
If you're going to use us for household current, be sure to wire up a switchbox properly. My Winco will power everything in my house except the electric backup furnace for the heat pump.
With 7 KW I'll be going for essentials..... rotating freezers and fridge.... using it for a few lights....... and the water.
I have a Honda 2000 EU to run the computer..... and that's the most important thing some days.
   / PTO Generators: Winco #4
I'd so some research into tiger power generators. You should be able to get close to 10kw capacity for not too much more money. I package with a generator, pto shaft, cart and cord set can be had for about 1800.
   / PTO Generators: Winco #5
Check out northern tool gennies as well.. I got a 12.5kw unit for? 999$.. pto shaft was another 180$.. I mounted mine to a KK carry-all.. using a spare (free) pallet.. I think the carry-all was 49$ ??
Soundguy
Their website indicates that 20 hp is needed to run the 10 KW..... nice! My 23 hp is ready for this.
I've added this to my short list.....
Anyone else out there that can recommed Tiger?
Thanks,
Richard
   / PTO Generators: Winco #7
</font><font color="blue" class="small">( Their website indicates that 20 hp is needed to run the 10 KW..... nice! My 23 hp is ready for this.)</font>
Remember that they are looking for 20 PTO hp, not 20 gross engine hp. If you don't have 20 at the PTO, you can still run it, you just won't get full output. A rough rule of thumb is 2 hp per 1 KW of output, so if you have 18 PTO hp, for example, you should be able to get up to 9 KW output before starting to bog down.
Having said all that, I run a 4 KW gas generator for our house (it does have an unusually high 6 KW surge capacity). It's a bit small, but I can keep my fridge and freezer going, and run the well pump and a few lights. I run into trouble if all of these try to start up at once, so I usually rotate the fridge and freezer circuits. I also have enough to run the small pumps for my radiant floor heat (propane fired boiler), but I try to run the wood stove, especially if the power is out.
My point is that you can "get by" with a lot less than most people think... especially if you have energy-star appliances and use energy efficient lighting.
John Mc
Thanks John for pointing out the PTO rating......actually I think my 7610 is a 24 hp.... anybody remember or know what the PTO rating is on the 7610? /forums/images/graemlins/confused.gif
   / PTO Generators: Winco #9
you'll have no problems with 10kw, we put them behind BX2230's all the time which are 18 PTO HP. As was said, you will get 9k on that tractor before the cycles will start to drift off some. You'll have no issues with a B7610.
   / PTO Generators: Winco #10
Have you looked at "The Power Connection" in VA. 800-895-9981
http://home.ntelos.net/~gener8s/
a few years ago I purchased a 17KW/35 surge, 1800 rpm, brushless generator, on trailer, with pto shaft, delivered to texas for 2500.00
They have others.
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2019 JOHN DEERE 8245R LOT NUMBER 187 (A53084)
2019 JOHN DEERE...
