PTO Generators? IMD vs Winco?
   / PTO Generators? IMD vs Winco? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
10KW units are similar in price.
Anyone have experience with the IMD? The adverts say "USA".
Mostly I wonder about the gear box ;-)
   / PTO Generators? IMD vs Winco? #2
I have never used an IMD, but I'd pick the AVR over the capacitor based voltage regulation, as it will give better voltage regulation.
Generally speaking, PTO generators aren't as good at regulating frequency as other generators, unless the tractor has a digital ECM to control engine speed.
All the best,
Peter
I have very little need for frequency regulation.
50/60 hz
Even the kitchen clock runs off a battery.
Thanks for your comments!
   / PTO Generators? IMD vs Winco? #4
You don’t have a well pump or other 60hz AC motor in your house?
Those certainly care about 60hz being under frequency
   / PTO Generators? IMD vs Winco? #5
"Close" to 60 should be fine for most motors. Microwaves tend to be a finicky appliance, and some UPS units have trouble outside of 58-62Hz.
@CalG I've run a WINCO PTO generator for a week more or less straight for 18 hours a day. My only tweak was to put the tractor in 1,000rpm PTO, and then drop the engine speed until the PTO was running 540rpm to save fuel as the tractor had a ton of HP, relative to what the generator needed.
All the best,
Peter
It's been a long time since I've run across an A/C induction motor that didn't read 50/60 hz on the motor plate.
All the best,
Peter
Yep!
I've got two tractors to choose from that have the high speed pto.
Our domestic needs are small, but the well pump needs must be met.
I'm sure the fuel economy of the .9 liter diesel will be noticeable.
   / PTO Generators? IMD vs Winco? #8
You’re confused. Most American market motors are designed for 60hz.
Running a 60hz motor installed to run at 60hz, at 50hz will cause obvious performance issues (20% slow), and if you’re not driving it with a VFD, then it’s going to run too hot and consume excessive current
   / PTO Generators? IMD vs Winco? #9
When I first tried running my 3/4 hp deep well pump off my 5k generator, it couldn’t reliably start it. Often just bogged the generator down until a breaker would trip, or I would kick off the breaker.
The generator was factory set at 60hz no load. When I measured, it dropped to 59hz with a moderate load, and 58.5hz when bogged by the stalled deep well pump.
I adjusted the no load to 61hz, no load. During startup there’s a quick drop to 60hz.
Deep well pump starts and runs perfectly now.
Deep well pumps can have enormous starting currents depending on well depth, static water level, and number of check valves
I have found modern induction motors to be very tolerant of both voltage and frequency fluctuations.
Most motors in my inventory today, which must be over 16 in number, (though several are 3ph) carry plated ratings for 200-240 volt, 50-60 hz input.
Of course, I'm not going to pull the water pump to assure you of that particular motor plate. But HEY! It's water cooled! I bet it can tolerate a "warm spell" several times per hour.
Just so long as it gets STARTED!
One hz? That is one fussy well pump motor.
2012 FREIGHTLINER M2 STAKE BED 24’ LENGTH (A43004)
2012 FREIGHTLINER...
2012 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A45333)
2012 KENWORTH T800...
2019 ALLMAND BROS, INC. LIGHT TOWER (A45046)
2019 ALLMAND BROS...
2018 CHEVROLET SILVERADO 1500 (INOPERABLE) (A45333)
2018 CHEVROLET...
1994 Toyota 6000lbs 2 stage forklift (A44789)
1994 Toyota...
2018 Freightliner M2 106 Medium Duty Truck, VIN # 1FVACWFB6JHJH4939 (A44391)
2018 Freightliner...
