Generator PTO generator
   / PTO generator #11
I modified the seat button on my 4010. Works fine. All you need is a couple of those wire jumpers that you can get at Radio Shack.
Both the 4010 and 4110 (and probably 4115 and 790) have identical buttons underneath the seat. The button on the 4110, 4115 & 790 works in the up position to allow you to use the PTO with no one on the seat. The 4110, 4115 & 790 have seat brackets that allow the operators to pull the button up and then sit back onto the seat to work the clutch to use the PTO on their gear transmissions. The 4010 only comes in HST and doesn't need the seat brackets, but the button does not work in the up position. Apparently the wires going back to the control module from the up position wires, do nothing on the 4010.
Here's the procedure to make the button work to operatue the PTO with the seat button in the UP position on a 4010 and to disconnect those wires from the control module, to avoid confusing the module if voltage is sensed from either of these wires:
o Locate a 10 mm wrench or very thin-walled 10 mm socket. You'll need an open end to remove the bolts holding the button in place unless you happen to have a very thin-walled socket that will go between the holes where the 10 mm bolts are holding the button in.
o Remove the button by pulling it down against the spring that holds it in position, in order to get the 10 mm wrench on the bolts. Or, use your very thin-walled socket.
o Use a screwdriver or one edge of the 10mm wrench to push the plastic clip holding the electrical connector together. Pull apart. You'll find the terminal underneath some plastic sheathing that can easily be pulled back.
o With a test light, locate the pair of terminals at the connector that serve in the button up position. These will likely be the mostly blue and blue-striped ones. The test light will come on with the button pulled up when you find the right pair.
o Just to check, use your test light to check that the other 2 terminals light the light if you push the the button down.
o Twist off the button-up connections with needle nose pliers.
o Plug back in and start the tractor, if you want to be certain that you did the right 2 terminals. Check that the rear PTO can be pulled out with the button pushed down.
o Remove from terminal connecter again and jumper the mostly blue & mostly red wires. You can do this with some jumper connectors you can buy at Radio Shack. You'll probably find these wires are side-by-side.
o Jumper the blue stripe & red stripe wires. Again, you'll probably find these are side-by-side. I couldn't put the 2nd jumper side-by-side but stripped off some of the plastic over the wires and located the 2nd jumper further down line.
o Just for insurance, I wrapped the jumpers with electrical tape. Then, plug into the connector and check PTO with button down and button up. Should work in both positions.
o Bolt button back into position.
If you bugger the job, you can get another button for $27.18. I have a spare, a 4110 one that I bought that has a different part # than the 4010 but is identical to it.
I think JD just screwed up on the control module internals somehow, and the lawyers had them put in the 4010 manuals that the PTO can't be used without someone sitting in the seat. Sounds as though they've done the same for the 2210/2305.
Somehow, the wires from the button up position on the 4110, 4115 & 790 must go back to the control module to sense the clutch action on geared models. Otherwise, I can't figure why JD didn't just join the wires at the button from the 2 positions and save a pair of wires back to the control module.
Ralph
   / PTO generator #12
Hi Whynot, what all did you run off of your generator during wilma? I have a couple portable units that i ran during previous storms, but want to go to one unit that will run whole house, understanding that i may have to alternate, pump, water heater etc. I am not sure what a central a/c unit would require. I have gas stove so no need there and i have a 65 hp tractor. I just wanna be prepared this year. <g>
   / PTO generator
RalphVa thank's for the info
Swiftboot
To do a rough calculation use this link generator buyers guide. At the bottom of the page is a chart with estimated wattage use for most household items. Now if it were me and I had natural gas from the street I would have one of the permanent generac unit's installed. Oh by the way I live about 50 miles from the coast and I don't think we lost power and if we did I don't remember it. Come to think of it I don't even remember the storm.
   / PTO generator #14
</font><font color="blue" class="small">( i have a 65 hp tractor. I just wanna be prepared this year )</font>
That 65 hp tractor sounds like it will run a 48pto hp 27.5 kw gennerator just fine. Northern tool has them for 1999$ My stepdad has one and runs it off a 50 hp JD tractor. I have the 13kw version. Both good generators.
27.5kw version will make 200a @ 120v and 100a @ 240v..
Soundguy
   / PTO generator #15
Whynot,
..... and I think I would be cutting it close if I can even use a 220 ckt with the trans switch cause the one I seen didn't have a blank for a double breaker.
)</font>
You can configure many of the Reliance brand Transfer Switches to use either single or double pole setups. Depending on the model, you can have up to 5 doublepole breakers. This link Reliance Controls has all of the specs for many of the transfer switches that Northern Tool carries.
I use the 6 circuit model and have one double-pole hooked up to my well-pump.
   / PTO generator #16
Swiftboot,
I don't have a PTO generator but thought I'd pass on my Generator info. I bought a 10KW welder / generator because I needed both a new welder and a bigger gen. to run my house.
House includes a 220v well pump, 1-220 A/C, 1-110 AC, 1- refrig/freezer, 1-chest freezer, 1-220 air compressor, plus all the usual lighting. It was in the mid 80's and the power just happened to go out the day I bought it so I had to run to the hardware store to buy a plug to connect the house to it. Once hooked up I ran the whole house with everything listed above including the 2 A/C units on for 6 hrs. until normal power was restored. I'm pretty sure if you got a 15-20K PTO generator it would probably run your whole house. My house with garage is fairly small <2000 sq. ft. Your 65 HP will run a good sized unit.
George
   / PTO generator
Ok after researching I am satisfied with the quality and saftey of the reliance brand transfer switch but, I have one last question before I order one. The transfer switch has single pole breakers and to make a double pole you add the bridge to the breaker on the 20 amp breaker's which gives you your double pole 240 ckt. Does this now mean in theory you have a 40 amp breaker ? The reason I ask is because I am going to do like soundguy suggested and wire in the water heater while I am wiring every thing in and use it only when needed. But the current breaker for the water heater is a 30 amp one and doing the OHM'S law calc that is the size it need's to be. Thank's again
   / PTO generator #18
No. If you take 2 20amp breakers and connect them together to form a double pole breaker then you still have a 20amp breaker with 20amps on each "leg". If your water heater is a 240v 30amp circuit then you need two 30amp breakers tied together because the hot water heater has two hot wires (each at 120v 30amps) going to it. So you need two 30amp breakers tied together (make sure your wiring is appropriately sized for a 30 amp circuit).
   / PTO generator #19
</font><font color="blue" class="small">( ...The reason I ask is because I am going to do like soundguy suggested and wire in the water heater while I am wiring every thing in and use it only when needed. But the current breaker for the water heater is a 30 amp one and doing the OHM'S law calc that is the size it need's to be. Thank's again )</font>
WhyNot,
I took a look at my manual and found this note
</font><font color="blue" class="small">( Warning: Transfer switch circuits with 20 amp breakers (the ones with the red
caps) must be installed on only those branch circuits with 20 amp branc h circuit
breakers. Transfer switch circuits with 15 amp breakers can be installed on 15
or 20 amp branch circuits. Do not install any transfer switch circuit on
branch circuits greater than 20 amps. )</font>
So it seems that you may have to install a separate single circuit csr-302 switch designed for water heaters if you want to go that route. It sure would be nice to have hot water. /forums/images/graemlins/smile.gif
One other thought, when you are choosing your transfer switches, make sure the switch is rated to handle your generator's output and that the power inlet/outlet on your switch and generator match.
Charles P
   / PTO generator
Today I finished this "little" generator project. I say "little" because as you are all aware you need to do a bunch of little project's to finish what you set out to do in the first place. here is a pic of the transfer switch installed. I bought the flush mount kit since I plan on sheet rocking the garage at some point. It is a Reliance brand manual 6 pos. switch rated at 7500 watt's and 30 Amp's at 240. Very easy to install and just like advertised no need to throw any breaker's just flip the 6 switches from line to gen with no back feed (I checked just to make sure)
2010 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2010 WACKER NEUSON...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A57024)
2021 John Deere...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft Insulated Bucket Truck (A55852)
2012 Freightliner...
3410 (A47477)
3410 (A47477)
