Generator PTO generator
   / PTO generator #1
mustelid
southeast michigan
given the recent blackout of the midwest/northeast /forums/images/graemlins/frown.gif ....any comments from anyone using PTO generator with their compact tractor?
   / PTO generator #2
When I was generator shopping I strongly considered getting the pto one. Cost was the same as a stand alone but would have had 13kw instead of the 8kw I bought. Only reason I didn't go with the PTO was if I had an outage in the winter I didn't want to have to disconnect the generator in order to plow and figured it would be cheaper putting hours on a generator than on the tractor. I think they're a great option though and all the farmers I know use them.
   / PTO generator #3
Power generation is a life and death matter to a chicken farmer such as myself. I once heard of a chicken farmer who got a pto generator for cheap and used that as his power back up. He lived at the end of a country road and was the last priority when they had a power failure. This farmer had to run his tractor solid for a week before he got his power back. Thats a lot of hours to rack up on your tractor.
Of course most needs are not as great. You could run it for a few hours every day and get by but gerald is right that a small stationary unit is probably better unless you need a pto generator for some other reason.
I know on my 85Kw generator it runs at a constant RPM so I would think these pto generators would need a constant 540 pto speed. If this is true thats pretty fast and a lot more noise than a small generator would make.
Eric
   / PTO generator #4
<font color="blue"> any comments from anyone using PTO generator with their compact tractor? </font>
Hope you don't mind me answering, as I do not use a PTO generator. I considered a PTO generator, but went with a stand alone unit because usually, around here, if there is a power outage there are also trees down, or heavy ice and snow. I figured I would need the tractor and would have to shut down power to the house to use it.
As for stand alone generators, we were at a state park earlier this week and a gentleman was working to repair a wooden bridge that was damaged by a falling tree. He was using a generator and a circular saw. When he stopped sawing, the generator went to idle. When he started sawing, the generator fired up to high RPMs. I've never seen a generator like that before and it was just plain neat. Unfortunately, I didn't get close enough to see the make or model /forums/images/graemlins/mad.gif
   / PTO generator #5
David, I've only seen a generator like that in use once and it was a Honda and it was over 20 years ago. It was a construction crew building the new office building that I was project manager on and I was surprised to see a generator like that myself. The foreman told me they had tried lots of other portable generators and that Honda was the best they'd ever had.
   / PTO generator #6
Many of the better generators work like that. They usually have a small car battery for startup, hourmeter and it also controls that idle feature. Without the battery the generator will run with the pull start but you lose the idle-up/idle down feature and hourmeter
   / PTO generator #7
I believe that all of the Generac brand models that are rated for 7500 continuous watts or higher have this idle down feature. Mine is a Generac Wheelhouse 5500 continuous and I've considered upgrading to 7500 continuos just to get this feature. I've talked the wife into many things, but I'm not winning on this one /forums/images/graemlins/blush.gif She knows I've calculated all the startup loads and we don't need the extra capacity /forums/images/graemlins/shocked.gif Guess I shared too much information /forums/images/graemlins/frown.gif
By the way...Generac is owned by Briggs and Stratton or vice versa. So, don't look for engine options other than Briggs on Generac models.
   / PTO generator #8
Does your idle function only work when utilizing the battery?
   / PTO generator #9
I bought a Coleman commercial unit last year. 14,000 surge, 12000 continuos. It idels up/down depending on no load or a load.
   / PTO generator #10
Just got my power back this morning. I was going towards a PTO generator but reading this and having my wife home alone if im not,I'll go towards the stand alone type.Now just have to find a good price on one with Min. 5500watt.
Lost power in April for 5 days and i said to myself im getting one,Looked around and thats it,now this!!! I'll be getting one right away NOW /forums/images/graemlins/grin.gif
TRUCKING INFO (A50775)
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
3 pt Aer-Way (A50514)
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2011 Mack CXU613 Truck (A52128)
2011 Mack CXU613...
