Generator PTO Generator 3 point mount??
/ PTO Generator 3 point mount?? #1
wr200man
I bought a Northstar 9000 watt generator 2 years ago during an extended blackout. It did not come with any sort of mount...at the time I did not care, as we just needed power to avoid freezing. I jimmy-rigged it onto a trailer and made due until the power came back.
Does anyone make a category One 3 point hitch mount (or kit) for PTO generators? I have searched the web and the forum without much luck.
I know northern has a trailer for the generator but it really does not fit into my storage area as well as a 3 point would (that and it is a bit pricey).
I would appreciate any help with this dilemma:confused:
/ PTO Generator 3 point mount?? #2
Search for a 3 point "carry-all"
TSC sells one for under $100.
You will have to make a deck and mount it-but it should be pretty easy.
/ PTO Generator 3 point mount?? #3
I was thinking the same thing. A carry-all would be very in-expensive and highly customizable. However, depending on how your generator is built, you will probably need to be careful to ensure that the PTO shaft from the generator doesn't contact the carry-all. Generally... I don't think carry-all's are designed with the idea for running a PTO shaft through the upper frame.
That being said, if you're careful, and you watch how high you raise your lift arms, it should work very nicely.
/ PTO Generator 3 point mount?? #4
Wasn't there a thread a while back about a carry all that twisted into a hunk of unusable metal when the generator went under load? Might be a good idea to check into that, or build your own carry all, but a little heavier duty.
David from jax
/ PTO Generator 3 point mount?? #5
I would make my own. I am agreeing that a carry all will not handle the torque. You would have more in it by the time you beefed it up.
Chris
/ PTO Generator 3 point mount?? #6
I got mine with a 10kw unit from IMD, I raised the legs so the shaft would be straighter, and modded it to go on an i-match.
the link shows the 3pt carrier but no price, got mine as part of a package but I think you could buy separately, you'll have to call for a price, this is a dealer for IMD, ask for Shannon
PTO Generator Accessories
/ PTO Generator 3 point mount?? #7
I bolted an old pallet to the bottom of my carryall.
If I had a PTO generator, I'd make some mounting holes to attach it to the pallet at the proper distance from the PTO shaft.
Ralph
/ PTO Generator 3 point mount?? #8
Could be great rotational torque, don't think you would want to trust any part that wasn't bolted. (nailed slats)
You could build it out of wood but you'd want to beef it up with all bolts and heavier wood.
/ PTO Generator 3 point mount?? #9
David from jax
A generator developing 9000 watts and being spun with a 540 RPM PTO will transmit a torque greater than 120 Ft Lbs to the support structure. That's a minimum value because it assumes the generator functions at 100% efficiency. To account for less than ideal efficiency and maintain a safety factor greater than 1.0, better figure at least three to four times that amount (400 to 500 ft lb) and design the support accordingly.
/ PTO Generator 3 point mount?? #10
One possible way to handle the torque on the carry-all is to weld properly sized wheels on to the bottom. It would make it easier to scoot around without the tractor, pick it up with the tractor to reposition it and it would be resting on the ground with the shaft almost level when in working mode. That was my game plan when I sketched it out a while ago but unfortunately I still haven't got the PTO generator and, the way things are going, it may remain on my "wish list" for some time to come.
/ PTO Generator 3 point mount?? #11
I've run my 13 KW PTO generator for many years on a standard old KK carry-all. You're little 9 KW will do just fine. I used a thick piece (1") of plywood to span between the carry-all arms and to mount the generator to. There is plenty of room for the generator pto shaft to come right through the carry-all opening. One thing to pay attention to when running the setup is to adjust the generator drive shaft as close to straight as possible by adjusting the 3-pt top link in or out and setting the lower links accordingly. To help stabilize the setup, I've occassionally slipped a couple of car jacks under the back end of the carry-all arms and lowered the setup (somewhat) onto the jacks, but still the bulk of the load is held by the 3-pt.
I've run everything in the house off of this, including the large starting loads of the well pump, wash machine, and air conditioner. Yes, you can tell (barely) when one of these kicks on, but it' no more than a little twitch of the setup and the tractor governor stepping up.
/ PTO Generator 3 point mount?? #12
How much pto HP does the tractor have?
How did you keep enough diesel fuel on hand to last you through the outage?
I have a Kubota L2800 that burns about 1 gallon per hour, I keep 20 gallons of fuel on hand at all times.
We ran the generator about 5-6 hours per day to warm up the house and to get the essentials done. Usually from about 5pm to 10ish.
We have geothermal heating so obviously running that was out of the question but we thought ahead and put in a lennox fireplace while we were building which runs on propane and a small fan...It does a pretty good job of keeping the temp tolerable during such events. With the geothermal we have floor heat and a very large supply of hot water...the hot water lasted 4 days without power.
With Last nights ice storm on the horizon, yesterday I shored up some of the beefier pallets that I had around to get the genny up to PTO level/Loaded it with paving bricks for weight and used my carry-all to put it all together. Hillbilly engineering at its finest :eek:(desperate times= desperate measures)...I will post pics later. It actually works very well.
/ PTO Generator 3 point mount?? #16
I was improving my generator setup and took some photos with my phone.
The plan is to feed the house from the shop and use the engine heat from the tractor to heat the shop while supplying the house and shop with electricity. Also shows the 3 pt platform my generator came on.
See if this works.
The two heaters were just to provide a bit of load. I also wanted to see how the tractor managed lighter loads at the higher PTO setting. It didn't like it, too slow an engine RPM at 60 Hz and the operator off seat flip up doesn't work at that PTO setting, only at 540 RPM. I didn't know that before.
/ PTO Generator 3 point mount?? #17
Glad to see that you are venting to the outside. How far does the exhaust extend out the door? 6" er 2'
/ PTO Generator 3 point mount?? #18
That is a 10 foot length of exhaust tube so extends well past the door. Interesting exhaust sound when outside with the doors closed so all you hear is the exhaust. Earmuffs are required when inside with the tractor running at PTO RPM.
I'm going to make up a short cheater cord so I can easily plug in a 4800 watt construction heater as well as the arc welder. I think it will be able to run the welder for lighter welds.
/ PTO Generator 3 point mount?? #19
I'm sure that this fits under the "no bull" category and it's probably way too
late to help you. Maybe it will help someone else.
I've done just exactly what you've asked for - a 9kw mounted to $150
carry all with a 1/4" plate steel deck for mounting - very heavy and stable
with no twisting.;);)
