PTO gear box
/ PTO gear box #1
bill0742
Bullard,TX
LS 3010
I need access to the differential gears. I have all bolts and hydraulic lines removed from the top cover. It is only sealed to the gearbox by sealant. I have tried very carefully to hit the top cover with a board and hammer to break it loose. Any suggestions? I am working outside with no power.
/ PTO gear box #2
I'm sure your lift arms are disconnected. Sometimes it will comes loose by sharply lifting the arms in the full up position. If you are carful, you can drive a thin gasket scraper between the two housings to get separation started, then a pry bar.
/ PTO gear box
Raising the arms and jerking up on them broke it loose. Thanks, I did not want to mess up the castings. Now to find out how to get the shafts out. Need to replace 2 gears.
/ PTO gear box #4
This is on the LS 3010?
/ PTO gear box
Yes it is. I've got one of those seals in the housing that is very insistent on staying put. I didn't want to destroy the seal,but looks like i might have to.
/ PTO gear box #6
You are probably going to have to split it at the trans to get where you are going. Good luck!
/ PTO gear box
No, I got the shaft and gears out O.K. without breaking it open. Thanks for your reply. It's nice to know that there is assistance out there if one needs it.
/ PTO gear box
Yes, it is on the LS 3010. Just waiting for parts now.
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Woods 1050 3-Pt Backhoe (A66285)
Woods 1050 3-Pt...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
Hay Feeder (A65640)
Hay Feeder (A65640)
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
