PTO Dyno
/ PTO Dyno #21
jgendr said:
yes I do get 23 MPG's.
Are you reading that from the overhead console?
what's your combo. Is this an ISB or a 6BT motor? what chassis dyno did you use (I am guessing Dynojet?)
-scott
/ PTO Dyno #22
I like the hydraulic pump idea with a load cell measuring torque. The pressure can be monitored for reference and even calibrated to indicate torque. Fluid can be run thru a radiator on the low pressure side. I probably have a rotary encoder in my pile of junk. The original disk brake idea is not bad either - certainly least expensive. It all depends on what is in your junk pile. A centrifugal pump might not be the best choice. They tend to spin easier at higher pressures as flow rate drops.
/ PTO Dyno #23
That's the truth! I don't know what a rotary encoder is, but that sounds
like a good pile of junk. :)
/ PTO Dyno #24
If I recall my reading correctly, when the first polaris nuke power plant was being developed and mocked up, they used a wet brake as their mechanical load. It basically had a garden hose flowing water over the brake assembly attached to the steam turbine gearbox to keep the brake assembly cool. A large disc brake with water cooling might work OK.
I think restricting the flow from a hydro PTO pump is the way to go, with the pump atached to a lever arm to give you a direct FT/LB reading. Very easy to control. I don't think I would bother with monitoring pressure and flow as the direct torque reading related to RPM is really what you are after for comparison anyway. You of course would need a large enough pump that the HP demand would exceed the tractors capacity to provide, before the max operating pressure was reached.
Whatever you use, it will have to be supported outboard of the PTO shaft to avoid side loading the PTO shaft. Any twisting of the lever arm would probably result in errors in the torque reading also.
/ PTO Dyno #25
I don't see how or why you would attach the PTO pump to a lever arm and
how that gives you a torque measurement. If you want to use a lever arm
for torque measurement, then you are simply back to a driveshaft and brake,
with a lever to hold the brake.
A hyd pump with fixed and known volume that works against a variable
relief valve will dissipate this much power:
hp = pressure (psi) x flow (GPM)/1714
increase the RV pressure until the motor can no longer maintain the set
RPM and you have your PTO output.
/ PTO Dyno
Man This is great, I love it when minds come together on a task!!!
xlr82v2: That is exactly what I was planning on doing, Do they Have any more info at that site that will explain the electronica setup, I couldn't find any
SPYDERLK: That is way cool, I thought I was the only one out there thinkin of this project!!! I love the turbo whine!!! I'm gonna build my own system from custome exhaust manifold to the turbo and down pipe to the exsisting muffler, or straight pipe it LOL
dieselgeek: 01 ISB, DD4's, HX40, 5'' from down pipe all the way out, Full blown Sun Coast ProLoc Tranny holley blue pusher pump, 3:54 gears! And I take all my reading from GPS. I know the overhead is about 20% higher than actual. What really Helps is the ProLoc Torque Convertor!!! Mine is a 91% so it's very tight! Major difference.
dfkrug: You Are exactly correct with your formula's and I was thinking of useing that idea, however, I started looking into purchasing a PTO Hydraulic Pump, And them suckers ain't cheap!!! $400 or better!!! And since I don't have one laying around that is kinda out of the picture! Unless someone Out the has one they would like to donate to the project ( LOL )
I do have the axels hear and most of the other stuff, What I do need is more info on the Data side. How to cheaply hook the load and tach to the computer. Some if that stuff is pricy too. Flee bay has some that I've been looking at.
Who Knows Maybe we can have a get together down in the South East and have a dyno and sled pulling day LOL That would be fun!!
/ PTO Dyno #27
What you said in post #20 was right- calibration and some care is needed. The formula here is to calculate the hydraulic HP delivered by the pump. It does not tell you the amount of power it takes to drive the pump. It tells you the HP the pump is delivering to the point where the measurement is taken. Youd have to be careful in order to get good answers at different HPs. Pressure would have to be measured at the pump port for one thing, otherwise flow losses would cause an error from one flow setup to the next. Best measure torque and rpm on the input shaft.
larry
/ PTO Dyno #28
jgendr said:
... We certify these numbers on a big dyno machines at our events. ... Now I'd like to try tweaking my yanny
Uh ... just take it to the event. Done! :D
If that's too simple ...
a pto pump needs to push against something. Measure that push directly, by jamming a bath scale between your towbar and a torque rod bolted to the pump. Load the pump down etc. Another poster mentioned the side loading, but I think the pto is designed to drive belts (all side load) at full output for the life for the tractor, so a minute's test shouldn't hurt it. You don't need a fancy tach. There's one on the tractor already.
But after tweaking it I think you will discover that weight, traction, is the real world limit on usability. Yanmars are already light, high horsepower tractors because their primary application is a big rototiller in the rice fields. So your efforts will increase pto output, but not have much effect on pulling ability since that corresponds to weight. Maybe it could run a bigger mower or tiller if that's what you are building it for.
You may find the output limit is defined by the cooling system's capacity, too. By the time you redesign that, you might as well have bought the next larger tractor where they designed all that in for you already.
If you go ahead - we want pictures!!!
/ PTO Dyno
Oh Definately Pics will be posted!!!
I emailed the gentleman that built the pto dyno that was pposted earlier. I'm waiting on a responce..
I am planning on useing a turbo from an Mercedes Benz 300TD, I like it because uses a standard T3-T4 mount on the manifold and the exhaust outlet has a built in flex tube. The waste gate is adjustable for tuning purposes, you can set it as little as 5 psi and as much as 20 psi. I know I'll never get anywhere near the high end for frear of blowing the head gasket. If it does blow I will be talking to a Diesel god guy I know about O-Ringing the block or head and ARP Studs!!! With this done on the dodges we see reliable boost pressures in the neighborhood of 100 PSI. if i keep the boost down low I won't need an intercooler, but not ruling one out! HE! HE! HE!
/ PTO Dyno #30
jgender I had sent you a PM the other day with some links to optical tachometers. I don't know if you did get that or not.Where I work we test a lot of Shimpo tach testers out but there are many out there. Running around the $80-200 range. They are kind of fun to play with. You can use them on other things besides the PTO. Fans and motors or tuning engines such as chainsaws or lawnmowers.
Optical Tachometer
Pocket Laser Tachometer
http://www.reliabilitydirectstore.com/Tachometer
Shimpo Instruments, Tachometers, Stroboscopes
/ PTO Dyno #31
Yes, use the pump like a hydraulic brake. Then as mentioned, you only need to measure the weight at the end of a known arm and RPM to calculate available HP. Any brake and lever arm method is going to turn that drag force applied into heat. Now, you can spray on water to cool the brake drum or rotor to deal with this(messy), or you could use a hydraulic cooler on the low pressure side of the restricted flow from the pump load system, back to the reservoir. Much cleaner in operation IMO...
With the variables involved with gathering these numbers from a restricted hydraulic flow, you would need to monitor, in addition to RPM, flow and pressure to make it as accurate as the braked lever arm already is.
Arthur Bell, when developing the first Bell helicopter returned test engines to vendors for failing to meet their claimed/contracted HP to Weight ratios. He determined this by measuring the torgue force applied to the helicopter tail boom at a given RPM, using a pull scale attached to a fixed object with a rope...
/ PTO Dyno #32
larry
Yes, the formula gives the power delivered (dissipated) by the pump, as
I said. And it only indirectly gives the power needed to run the pump.
These hyd systems are generally regarded to be about 85% efficient, as
I also stated. So a .85 factor is used and callibrated with a known unmodified
tractor or 2.
But although I think a PTO pump and adjustable relief setup is an elegant
approach, it is certainly not cheap, as PTO pumps ARE expensive. JGENDR
correctly points that out. The drive shaft and brake has its advantages.
/ PTO Dyno
Well I got in touch with the gentleman that built the pto Dyno today. He is sending me some more detailed pics and info on how he did it. Great guy to talk to!!!! He says he has like $25 in electronics and maybe $100 in the whole project. He says it good for up to 75 HP and over 1000lbft of torque!
NICE!!!!! When I get this thing together I'll be ready to test!!! And If all goes well, anybody interested can PM me and we'll see if we can put together a get together and do some dyno testing if your interested.
More to come soon!!
/ PTO Dyno #34
Sounds like a great project....and VERY reasonable costs, too. I look forward
to seeing pix of your dyno.
/ PTO Dyno #35
I wonder if a turbo off a Smart Car would be a better match. I'll guess those are 1500cc and turn 7,500 rpm.
Your Yanmar is what, 1,5000cc?? And it turns 2,500 rpm max.
A turbo off a car with 3x the airflow should be sufficient, I would think.
/ PTO Dyno #36
dfkrug said:
[[[Yes, the formula gives the power delivered (dissipated) by the pump, as
I said.]]] And it only indirectly gives the power needed to run the pump.
tractor or 2.
[[[No, including the energy of its output the pump dissipates the entire PTO HP, and you didnt say. The pump outputs/delivers approx 15% less than input, and the formula was used on output, without correction, to be the PTO HP.]]]
The fact that it was an indirect relationship was lost in #25, and should have been restated there and in every case where special measures are needed on a case by case basis to produce accurate results.
Hydraulics is a good approach. As you say, if the hardware is not on the shelf idle youre going to spend some $ setting it up.
larry
/ PTO Dyno
To All Interested,
I contacted the gentleman on his dyno that he built, He updated his website with more detaild pictures and info on building it.
Great Guy and great job!!!!
If you are interested in this project check out his updates:
Tractor Dynomometer
It's time to play Folks !!!!! LOL
California:
Most of those turbos that you are refering to are t3 t4 type turbos and a gas turbo will not spool as fast as we want. You are correct there, however the mercedes Benz 300 SD is a diesel, and has the smaller exhaust turbine which will make it spool quickly for my application. Yes It will make more boost than I actually need, but the other nice feature it has is an adjustable waste gate where you can set the boost that you want! Something most of the Gassers cant do unless you use an external waste gate which addes $$$$ to the project.
This is gonna be fun!!!!
/ PTO Dyno #38
jgendr said:
California:
There is no designation by turbo manufacturers as "gas type" or "diesel type" - also, most OEm turbos include a wastegate but not necessarily all are adjustable to the range you're looking at.
What's the displacement on your tractor engine? I have a feeling the 300D-T turbo off the inline 5 mercedes, which displaces 3.x liters, is going to be way too big to provide the low boost you're looking for. The best way to find the right junkyard turbo is to calculate your engine's airflow in CFM, then lay that over a compressor map which is available for nearly every OEM turbo out there. Not2Fast: Where Science Hits The Road is run by a friend of mine, he's got maps and a program that lets you key in your engine specs - it might work for this application. If confusing, let me know and I'll try to help you find out exactly what turbo would fit your needs. My gut says something off a 2 liter (or smaller) turbodiesel, like a VNT turbo off a wVW TDI engine, or possibly a 14B turbo of a 2 liter Mitsubishi gas engine, is going to be more appropriate.
-scott
/ PTO Dyno #39
jgendr said:
To All Interested,
Tractor Dynomometer
So Jgendr how is the dyno project going?
/ PTO Dyno
Gettin Parts and doing auto cad drawings now!!!
Ive got the schematics from the gentalman that designed it, and working on getting the electronics or researching data loggers now
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A66738)
2020 Ford F-53...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2006 MACK GRANITE CV713 DUMP TRUCK (A65057)
2006 MACK GRANITE...
2017 Peterbilt 320 New Way 20ASL 20yd Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
